Have you thought about what would happen if your switch would not open the seat release and you needed gas? I asked the dealer about this. He said to just pull up hard and something will let go and we will fix it when you get back. Figured there had to be a better way. So, I took a length of fishing line(strong and thin) and created a loop to put it around the mechanism that has to move back to let it open. You can see this by working your key to open and watch the cable connection. On the other end, I tied a small key ring that I can pull on. I put the ring up in the glove box. you can barely see the fishing line but if ever would not open you simply open the glove box, move the line down run along the inside of the seat and pull the ring. Now you are open and can get fuel without ripping your seat up. Not sure why they even have it lock. Thinking of just taking out the connection and letting the seat sit without locking in. Don't see an advantage to the lock which if they want to steal your gas they will just rip open the seat. Just some food for thought.
Vendors: Air Hawk2 seat air cushion, Adjustable Side Window Deflectors, slip-on grip covers, RAM GPS mount & a short RAM socket arm... with a bicycle handlebar bell mounted to it - a carryover from my 2-wheeling days, it was great for getting your ridng buddy's attention when stopped at a traffic light
Here's my version made with wire. After I took this pic I bent the wire tighter around the latch arm. I can pull the end of the seat out just far enough to reach and grab the loop.
Re: Thinking of just taking out the connection and letting the seat sit without locking in.
This what I did. I really do not see a downside.
Jerry Baumchen
Just facilitates someone siphoning the gas out of your tank, or stealing your tool kit, but other than that, not much. Under the seat is a convenient place to carry the adjusting wrench for the Tri Axis handlebar while you're tweaking its position.
.These would be my last TWO worries ........I was an LEO for 37 years and never heard of GAS being stolen from a Motorcycle.....and as far as the tools go....How many posts have we seen about people claiming they bought a Spyder for $ 30,000 and didn't get any tools .....Because they couldn't find them and they owned the Bike ....Mike
they could take my whiz-bang toolkit. I think the straps that held it in place are more valuable
as helmet strap extenders enabling the use of the virtually nonfunctional helmet hooks.
As someone previously stated in some seat install chats, the seat doesn't really need to latch, just use the
pin to "locate".
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
I tried just disabling lock, but my gas shock is too strong and the seat will come up if you aren't sitting on it. The fishing line/wire is the trick I think, cutting the seat so that iut folds back is even better and BlueKnight's "door" is clever too.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
Why would anyone steal that superdopper imitation tool kit
this posting has been vetted, scrubbed and endorsed by the committee for postings
You are spot on Mike. I try to not worry about what could happen and think about what is happening now.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
my release cable broke a long time ago so I filed a taper on the other side of the pin that goes into the latch assembly,The latch still holds but just have to give a pull up and it unlatches
At one point I took the shock off and kept a small length of pvc under the seat to prop the seat up.
2014 RT Limited Matte Silver,Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars, Will it ever stop--NO
My seat latch got stuck too. I took it to ProCaliber, in Vancouver, Wa. They got it opened and, together, we decided to disable the latch with a zip tie. Works great and I just have to lift the seat for gas.
Ride in comfort,
John
You dont have to disable the latch, Just unscrew the post from under the seat and put it in your super dooper tool kit.
After you do this and discover lots of scratches etc. on the back of the gas tank you will wish you didn't remove that post .... the seat WILL move forward / backward when you are riding it .... that POST prevents that movement ..... Mike
