DOES ANYONE KNOW?
Where the horn is located on a 2017 RTS, and how easy/hard it is to get to and replace?
2017 ??
Not sure. I'm assuming it's the same as my 2014, which is under the left access panel. The one behind the wheel with the rubber grommets.
IBA #47122
2020 RT Limited Asphalt Grey
Not sure....
From the wiring diagram it looks to be on the right side, looks to be behind that lower panel. Now it does not show the panels etc but that is where to look for it....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I agree with Gene. Looked at a '17 and found they moved it to the opposite side.
I recommend a web search for "2017 spyder rt schematics". That may show you.
2011 Spyder RT-S
LtCol, USAF Ret
Proud Patriot Guard Rider
cheapcycleparts.comhttps://www.cheapcycleparts.com/oemparts/a/cam/57d2c02e87a8660e6845ba66/electrical-system-general
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
So it would appear that no matter which side it is on, it is relatively easy to get to and change. Many thanks to all.
We are still waiting for pictures of the new Spyder!!!
So am I. The sale should be finalized early this week, then another week or 10 days to ship it to me from imotorsports and pick up "The White Lemon." I'll be glad to see it gone, but no one will be happier than Val. And as it's been said, "If Momma ain't happy, ain't nobody happy."
Early 2017s are actually visible, behind the left hand pop off panel.
(this is how you will know if it's early/late)
the horn exchange on these could not be easier.
Other location ? not sure, because mine was early, thank goodness.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
Horn Location late models
Mounted center of frame you need to remove the skid plate and then left panel behind it lookup it's there. Thats left from the front bumper or right from the seat. On mine I extended my wires and mounted it behind the left service panel setting on the seat. I left the old horn in place in case its needed again.
Nicely done.
Now you'll have NO excuse not to go riding with me.
You're comments remind me of my feelings towards one of my ex-wives.
"She walks on the ground I worship".
IBA #47122
