SpyderLovers Founder
F3 Idler Pulley install video
Lamont, you're a good man.......but we all knew that. Not even one of your products and you still went to the trouble of making an install video. Thanks very much
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Idler
Thanks that was most helpful. Really liked your use of the screw diver and hole punch.
it was useful to see the tolerances and alignment to the belt.
Thanks again
Really good video! Quick couple of questions;
1. Should the belt alignment be adjusted before installation?
2. How will this effect the belt tensions? Any changes in procedure when adjusting tension?
Thanks once again....
You always keep us up to date on the new items Your and others ...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Install
Installed mine today..took about 30min.. Then.....took it for a ride...up to 70mph.. I am very very pleased..almost smooth as silk..Will make for some great long rides..
Where did you find one? Dealer here acts like I'm crazy. Is there a link or something?
thanks
Here you go Steven.
thanks
Here's an install thread with the BRP part number Steven. It's your turn to go look at your dealer as if he is an incompetent for not knowing what BRP has released.
http://www.spyderlovers.com/forums/s...412)-Installed!
HeliBars Handlebars
Kenda Kanine rear.
Pitbull has them in stock.
thanks
My dealer in Sierra Vista AZ had it in stock!!!!
bolts
got mine today from power sports no bolts does any one know what they are
There are two 13mm bolts that are already on the F3 holding the rear foot pegs. Those two bolts are also re-used to install the idler arm bracket that sits on top of the existing hardware and you just need to Loctite down the two 13mm bolts when you put them back in to install the idler pulley.
thank you
Do NOT use Loctite only use blue thread lock
Thanks, I actually used Permatex Threadlocker Blue which I suspect is a similar product to Loctite Blue. Loctite is a brand, blue or red are the strengths IIRC.
