Results 1 to 6 of 6
    Nov 2015
    Cypress
    Default F3T mirrors shaking? Got a fix for you
    Recently I posted on here if any other's on this board noticed their mirrors shaking/vibrating a little bit too much on the F3T and maybe the Limited? A couple of other's said they did. Today while adding some Lamonster goodies to the bike I had the mirrors off and decided to see if I could stop that shaking. I think I did come up with a cure. Note the pictures below and how I laid out some weatherstrip foam on the back of the mirror. I used 3/16x3/8 foam weatherstrip attached to the back of the mirror to take up the slop on the mirror mounting. Note the pictures and try it out yourself. You will be pleased.
    2016 F3T , Pearl White
    Default Well done...
    Should do the trick.. just needed you to go into it and find the solution...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Harrington, Australia
    Thanks Buckskin, I'll definitely give this a go......
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2012
    Junction City, KS, USA
    I definitely need that. Probably won't get it done till after the Homecoming, though. Thanks for the tip!
    PrairieSpyder (Patti)
    Nov 2015
    Cypress
    Takes about 5 minutes each side. Probably one of the easiest and quickest fix I can remember doing.
    Buckskin
    Quote Originally Posted by PrairieSpyder View Post
    Nov 2015
    Cypress
    I got here as quick as I could....🤠
