01-28-2018, 06:51 PM
#651
Originally Posted by A1A
Mike, thank you for the info my friend. Yes I read about half the DESS Thread and my eyes were starting to turn red and were burning. I just had to stop reading it. I'm still under warranty so the Dealer should address this issue for me. The display I had on the speedo said DESS and below that it showed the engine blinking, but no key image at all.
Cheers
Yes, the dealer should take care of the issue for you, it is covered "UNDER WARRANTY". Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
01-28-2018, 06:53 PM
#652
Originally Posted by PaladinLV
The only for sure way to fix it, is replacement of BOTH the DESS module AND you ignition switch (which will also get you a new key).
Good Luck!
AJ
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
01-28-2018, 07:01 PM
#653
Well I got the DESS check engine on the speedo today 1-27-17. I turned the switch off and on 3 or 4 times and got it to start. I have 18,997 miles on my 2014 RTL-SE6 spyder and this is the first DESS issue for me. I guess I'll keep riding it for a while and see if it happens again.
I had the (DESS) replaced twice (both times under Manufactures Warranty). The 2nd time they replaced the DESS module, ignition switch, keys reprogramed, new lock on the trunk. The above was replaced in Aug. 2014. Since then, I have not had the DESS code show up, and I now have 22,060 miles on the Spyder.
Keep us posted!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
01-28-2018, 07:07 PM
#654
Originally Posted by rustynail51
can hooking power supply cords such as heated clothing cords or trailer wiring harness directly to the battery give a d.e.s.s. code when neither is in use. The dealership asked these questions when trying to figure out why i continue to get the code after they replaced the d.e.s.s. module.
I run heated clothing and have no issues.
When mine acted up the module was replaced and so far no more DESS messages.
01-28-2018, 07:08 PM
#655
Originally Posted by Deanna777
[SIZE=2] Yes, the dealer should take care of the issue for you, it is covered "UNDER WARRANTY". Deanna
Maybe out of warranty unless it was extended??
01-28-2018, 07:31 PM
#656
01-29-2018, 09:57 AM
#657
It is Covered under the "Extended Warranty"( B.E.S.T). Ask your dealership.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
01-29-2018, 10:08 AM
#658
We prefer the nuclear option. Just turn DESS OFF and be done with it. Useless system that only serves to keep the owner from riding. Does not deter theft by any knowledgeable vehicle theft team. Its easily bypassed without the key present.
01-30-2018, 06:27 AM
#659
Jcthorne... how do you bypass? Mine is 2016 F3S SE6
01-30-2018, 07:55 AM
#660
Requires MegaTech version of BUDS. Several shops around the country offer it, including ours. Most dealers do not opt for the upgraded version that has access to the security system.
In BUDS, its a simple toggle of a setting.
01-31-2018, 07:43 PM
#661
Gremlin Bell
Sway Bar with Links
Half Cover
02-06-2018, 10:40 PM
#662
Well I have an appointment to take my Spyder into the Dealer 2-9-18. So will see how everything goes. I have to get it fixed because I don't want to get stranded out some where. Will let you know how it turns out.
Cheers
2014 RTL-SE6 Cognac (Current Love)
2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
02-07-2018, 04:58 AM
#663
SpyderLovers Ambassador
Thank You All. I had considered buying a used 2014, (in year 2016). I am now VERY glad that I went with a NEW 2016 RTL. PS: I did my homework on 'SPYDERLOVERS' Forum.
ENJOY YOUR LIFE WITH A SPYDER
02-13-2018, 01:02 PM
#664
Well I picked up my Spyder this morning from the Dealer 2-13-18. Here is the Dealer comments as written on the work order. No codes stored in (BUDS). But we and BRP have seen this before, BRPS recommendation is to change out the DESS MODULE. If it comes back, then replace the DESS ANTENNA. So the DESS MODULE was replaced, and both my keys were reprogrammed. This was accomplished under extended warranty and with no charges to me. I'm a happy camper and hope that this takes care of my DESS issue.
Cheers
02-13-2018, 07:36 PM
#665
Cheers
The 2nd time my dealership replaced the DESS MODULE, Ignition Switch, Reprogramed the Keys, Changed the trunk lock/and gave me a new trailer lock (On Aug. 28, 2015). The above work was done @ 8,740 miles, and since then I have not had the DESS Key code show up on the screen. My current mileage is 22,000. Also, I have a 2014RTS-SE6.
The first time (on July 14,2015) my dealership replaced only the DESS MODULE.
I hope you don't get the DESS issue. Good Luck!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
02-13-2018, 07:48 PM
#666
I am guessing go with the cheaper repair first then the harder more expensive repair next if the module doesn't work out.
02-14-2018, 12:12 AM
#667
Deanna
Thanks Deanna, I had 18,803 miles on mine when the DESS MODULE was replaced. I also hope you do not get another DESS issue as well.
Cheers
02-15-2018, 08:29 AM
#668
anyone close to nw illinois that can deactivate.?-- irv toms
[joyce & irvin toms]
02-15-2018, 11:26 AM
#669
That DESS "antenna" they are speaking of is part of the ignition switch on a 2014. So the ignition switch is what they will replace.
AJ
Well I picked up my Spyder this morning from the Dealer 2-13-18. Here is the Dealer comments as written on the work order. No codes stored in (BUDS). But we and BRP have seen this before, BRPS recommendation is to change out the DESS MODULE. If it comes back , then replace the DESS ANTENNA. So the DESS MODULE was replaced and both my keys were reprogrammed. This was accomplished under extended warranty and with no charges to me. I'm a happy camper and hope that this takes care of my DESS issue.
Cheers
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
02-15-2018, 06:55 PM
#670
Cheers
A1A, I hope I don't get another DESS issue either. If I do I'll post on this Thread ( which I started in July of 2015), If I do I know it is covered under the B.E.S.T Warranty.
Good Luck!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
02-15-2018, 07:02 PM
#671
AJ
AJ, Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
03-22-2018, 09:00 PM
#672
Gremlin Bell
Sway Bar with Links
Half Cover
05-28-2018, 07:34 PM
#673
Gremlin Bell
Sway Bar with Links
Half Cover
05-28-2018, 08:10 PM
#674
Cheers
I've had my DESS module replaced .... by real BRP Tech's ...... they told me the keys have nothing to do with the DESS module ..... and they didn't do mine .......... So either your dealer isn't as up on this as they think they are, or they just did it anyway for some unknown reason ...... Mike
05-29-2018, 08:22 PM
#675
I placed an order today for a DESS Module #710004916 with Cheap Motorcycle Parts. I am to have it next week sometime. I will switch it out myself. I have a 2015 Spyder RT and have had it little over 10 months and have put over 10,000 miles on it. It now has 20,700 miles on it. I have had DESS Key orange screen about 4 times, once last September and about two weeks ago and all I have ever had to do is remove the key and put it back. I was not much worried about it until BLUEKNIGHT911 tells me I am going to be stranded. I sure hope this is all I need. I only have one key so as soon as I get the module changed I have a blank key and will have it cut and someone program it for me.
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
