Results 1 to 7 of 7
    Apr 2017
    Villanova, PA
    Default Rear Luggage Rack for 2016 RS
    Thanks for the responses to my last luggage post. The issue I have is that all of the hard an soft side saddlebags take up the room for a passengers legs and also are likely to hit the tail lights which stick out on my model. I looked for a rack that I could fit behind the seat that would be attached to the rear or the back bumper. Does anyone make a rack for the 2016 model?
    Default Depends....
    You can modify the turn signals and some hard bags have them built in. As for a rack, if you have a back rest you can add onto it for soft luggage or Givi for one has a hard case you can put on. Check our sponsor/vendors seems there are some solutions there. I made my own with the oem back rest/rack offered for the early models...mine is a 2012 RS
    20160225_101925_resized.jpg 20160225_102032_resized.jpg 20160225_102206_resized.jpg soft bags from Kurakyn one for long trips one for shorter ones...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2017
    Villanova, PA
    No back rest, just the standard seat.
    Aug 2012
    CO
    You can drill the can am sport rack for mounting an adaptor plate for a hard trunk on it. (ie Givi etc) http://www.ebay.com/itm/Can-Am-New-O...-/181018370295
    IIRC there are a few forum members here who have done that.
    JLohPhotos
    2008 GS , Millennium Yellow
    Bossier LoUiSiAna
    Quote Originally Posted by asp125 View Post
    Last i saw the sports racks would only fit up to the '13's i got lucky there, but maybe that was just for the ST's? Here are pics what ive found already done:
    image.jpgimage.jpgGood renforcement & what i plan to try when i add my tourtank aux gas supply. Anotherimage.jpglooks like uses grip bar bolts under the seat? But i have no info just tha pic
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    I just got the same one from the same seller on Amazon.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I had it in my wish list for some time, it went down to $98.20, but went back up right after I got it. The only good deal is on the Silver, I will be making it black with Plasti-Dip for now.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Apr 2017
    Villanova, PA
    I figured out another solution. I'm going to mount 2 angle irons to the bolts that hold on the plate above the rear wheel so they stick out about 12" to the rear and then mount a plate to them with a spacer at the rear to level the plate. Total cost for 2 angle irons and a metal plate less than $10!
