Results 1 to 16 of 16
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    Default Broke my right side footrest bracket.
    I was an idiot and put a tad to much side pressure and my bracket, when moving my seal floorboard to the side to get my tupperware installed, after I put on the heat management system.
    I'm looking to see if anyone has a good source for a footrest bracket? I am looking used if possible. If anyone has a GS or RS parts bike, or a good motorcycle junk yard near them I could use the help. Thanks
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Apr 2011
    GREENVILLE, SC
    Default T.I.G.
    find a good T.I.G. Welder, and have him/her weld it up.... you'll be ok....
    Dan P
    SPYD3R
    Mar 2017
    Question
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R
    Even though it is cast? It will need to hold some weight, It is a main mounting point for the Seal floorBoards. Will it still hold?
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    Apr 2011
    GREENVILLE, SC
    Default WELDS
    Quote Originally Posted by Huked View Post
    most welds are stronger than the parent metal... find yourself a guy/gal that knows the requirements of welding aluminum... it needs to be heated prior to welding, alum tends to disperse heat faster than other metals, so adding heat prior to welding is a necessity... most GOOD body shops will have the proper equipment and personnel... check around... and good luck....
    Dan P
    SPYD3R
    Sep 2014
    USA
    check ebay..all kinds of used parts for sale
    Mar 2017
    Yeah I looked, only seen a left, if you seen one please let me know. People post stuff all the time under different names. I just ran out of names to call it in a search.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Might can give these people a call.
    http://stores.ebay.com/PinWall-Cycle...=p4634.c0.m322
    David
    Jul 2011
    Mitchell, Ontario, Canada
    705004182 Silver RH Foot Support. RS $102.99 USD
    Be careful what you pay for a used one.
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    at that price get a new one
    Oct 2011
    Magnolia, Ms
    Price on new one here. try this link. select #50 in the silver and add to cart. Part is $77.24
    http://www.powersportswarehouse.com/...E5/70337/70343
    David
    Jul 2011
    Quote Originally Posted by Warlock View Post
    Sorry but that link will only work for you only because it is your cart. No one else can see it.
    Default Little checking..
    cheapcyclepart.com has them also for 102.99 but if you google used motorcycle part you will find outfits that will search nation wide for the part...
    Oct 2011
    Magnolia, Ms
    Went back and redid link.
    David
    Mar 2017
    David
    Thank you for looking around, I do appreciate the help. It is funny though, you found the best price I have seen at $77.24. I found a site that sells it for $92.68, the best price before you. Then I look deeper, your site charges $23.94 to ship and my site only $8.50, with the total for both sites the same price of $101.18. Good deals never seem to be as good as we think . On the other hand if I can find something else to buy, they both have free shipping on orders over $99. I will be looking on your site as it gives me $21.76 to play with. Then I will be getting the part I need and something I can use for the same price as if I had paid the high shipping cost.
    Again thanks to everyone for looking and giving me some ideas.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    Oct 2011
    Magnolia, Ms
    Be a good time to order some filters to make up the difference. JAT
    David
