Page 1 of 9 12345 ... LastLast
Results 1 to 25 of 214
Thread: F3 Vibration
    Jun 2015
    Sparks, NV
    Default F3 Vibration
    So, I took my new F3 on it's first long ride yesterday which entailed some freeway driving. Turns out I have the belt harmonics between 67 mph and 72 mph. Has anyone found a solution to this issue, or has anyone had any success with a resolution through Can Am.
    Registered Users Ronbo's Avatar
    Mar 2013
    Arkansas
    Default Harmonics
    Quote Originally Posted by ca8920 View Post
    Having baker belt tensioner installed next week.. Will post results.
    Ron
    Jun 2015
    East Coast
    Default Any luck w tensioner?
    Quote Originally Posted by Ronbo View Post
    Ron
    Any luck with the belt tensioner? Brought my F3 home today and I noticed it on my inaugural ride home.
    thanks!
    B
    Clermont, Florida
    I had my dealer adjust the belt so the harmonic now occurs between 105 and 110mph and since I limit my ryding at those speeds I don't notice it much. Incidentally for anyone who has not tested it, the F3 will go much faster than that.
    May 2015
    Canada
    Yup notice the vibration bigtime... it starts at about 105km/h and goes till 115km/h then disappears. I feel it in my handlebars, seat even through the seat. It's hard to believe that BRP never felt this when they were test driving the prototype F3's!! I'm really curious if a belt tensioner will fix this issue and how long will it take BRP to do something about it
    Jun 2014
    Micco Florida
    Default F3 vibration
    I sent an email to Steve M at BRP care asking if BRP has a plan to mitigate the vibration on our F3s,it will be interesting to see what, if anything, can or will be done to make this annoying vibration go away.
    dealer said it "was normal " that's the same answer I got when I complained about the heat issue I had on my 2013 STS,and we all know how that worked out.
    we shal see
    Apr 2015
    Boise Idaho
    Somewhere else on here this was brought up and what was thought is that it is an engine vibration at a specific speed when in 6th gear not the belt. When I felt it on mine I down shifted out of 6th gear and the vibration was gone.
    Nov 2014
    Temecula, California
    Sorry,
    To hear you have the vibration issue, too. I posted about it in Feb. just after I got the bike. Very frustrating. Dealer double checked the belt alignment
    and tension but it was right on spec. so I still have the vibration. BRP said it was due to the length of the belt. The guy I talked with said not to add a belt tensioner because the added tension could cause other issues in the long run...
    Hope you have better luck, Please keep me posted if you find a fix.
    thanks.
    DJ
    2015 F3S , Black & White
    Mar 2013
    Arkansas
    Default VIBRATION... IS NOT:
    Quote Originally Posted by Retired 2012 View Post
    Sorry,
    thanks.
    DJ
    Normal, and it's not the engine....I've even had knowledgeable BRP people tell me it's my imagination... Stay tuned..I think some very smart forum sponsors have figured how to reduce or stop it. I added a belt tensioner On my 2013 RT, MY 2014 RT, and that SOLVED the problem . Further, it caused no problems. Belt tensioner goes on F3 tomorrow
    Ron
    Active Member Air Wing Guy's Avatar
    Jan 2012
    Ohio
    Default Baker Built Belt Stabilizer
    We at Baker Built have a belt stabilizer that will not add any more tension on the belt but will take the vibration out. Please check us out on our web site where you may view pictures of the belt stabilizer.
    Thanks, Mike
    Jul 2010
    kansas ottawa
    some have said to not use 6th till your past 70mph and you wont feel any vibs.6th gear unde 72 mph is bogging the engine. try it and see for yourself.
    May 2015
    Canada
    It's belt vibration not engine vibration!!!! That i'M POSITIVE Horrible from 105km/h to 115km/h then goes away.
    May 2015
    Ft. Lauderdale, Florida
    Default F3 Belt Vibration
    Had my new F3 to 2 local dealers and they both advised belt was in normal spec and tension. Both said vibration was normal with spyders. Hopefully smooth spyder will have a new product for the F3's shortly.
    Jun 2015
    Seattle area
    Default World's most expensive vibrator!
    Quote Originally Posted by mikedoucette66 View Post
    I too, got the same run around at the dealer today! I was told that it is normal for the F3's to do this. The salesman that sold me the bike said he couldn't feel it much at all. I spent a lot of money on a vibrator, not happy with the dealer that had the gall to charge me a 1/2 hour labor to look at the belt, and tell me everything is fine!!
    st.louis
    Default belt vibration
    everyone is talking about the speed at which vibration occurs; need to be looking at rpm and then shift down to the no vibration rpm.
    just shift out of the vibration zone......stop lugging the engine / drive line.
    Jun 2015
    Seattle area
    Quote Originally Posted by cmungen View Post
    The engine is not lugging in the least! It is a very annoying vibration. You can drop the RPM's below 3800-4100 or above and the vibration goes away. So lugging the engine is not even part of the equation!!
    Jul 2015
    Surprise, AZ
    One would think that this harmonic, if RPM related, would also occur in the same RPM range in lower gears, but I don't see this in the postings....Everything revolves around speed in 6th gear. Hmmmm??????
    Apr 2012
    Northglenn Colorado
    Bogging the engine is in the equation. Learn to shift the beast correctly and vibration is gone.
    Jun 2015
    Seattle area
    Quote Originally Posted by Tazzel View Post
    Do you have an F3?
    Houston
    No, its not. The vibration happens right in the engine's sweet spot on the torque curve. Not bogging, not lugging, driving correctly goes right through the belt harmonic range. And it is very annoying. yes you can drive around it but you should not have to. Not in the range it occurs. Its a defect in the design, not improper riding. This is starting to sound like the heat defects in the 2013 RTs. Yea, that was all in my head and over filling of the tank too......
    I too hope SmoothSpyder comes out with a well designed tensioner that solves this.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2012
    Northglenn Colorado
    Quote Originally Posted by RedStar View Post
    Do you have an F3?
    Yes I do, do you?
    May 2015
    Abbeville Al
    Vibration is a pain!
    Apr 2012
    Northglenn Colorado
    Yes, I do have to agree, you should not have to drive around the vibration. I don't think a belt tensioner is going to solve the vibration issue but I hope I am wrong.
    Jun 2015
    Seattle area
    I totally agree not having to ride around the vibration. I have had several bikes over years, many of them belt driven w/o vibration problems. I am really disappointed with mine, it's so annoying to ride. .
    Mar 2013
    Arkansas
    Default Luggimg
    It doesnt vibrate when the engine is lugging
    ron
