Results 1 to 9 of 9
    Jul 2018
    Wellington, Nevada
    Default Filling radiator over flow tank?
    Thought I'd check my reservoir tank today and it was a bit below the cool level. When I tried to fill it, the reservoir filled up to the neck, but the fluid level in the tank stayed at the level it was when I started.
    Seems like the tank did not let the antifreeze go into the tank??
    Is there something in the tank the prevents the antifreeze from going in?
    Im confused.
    Bossier LoUiSiAna
    Quote Originally Posted by Frankf View Post
    Im confused.
    We're confused because you didn't tell us what you have . Secondly when you tried to fill it was it running?
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Since he posted in RT shop talk, guessing he has an RT, just not sure which year. I know with my 2010 RT, I have filled it up and then noticed it drops down to the upper fill mark. Not sure if there is some sort of plumbing to account for that or not, but as long as its at that mark and the needle stays out of the red, Im happy.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Jul 2018
    Wellington, Nevada
    Default Antifreeze fill
    Sorry, its at 2014 RT-S.
    Read the manual, but it doesn't say anything special. Says to NOT overfill.
    No, bike was not running. Never heard of a cooling system that had to be running to add coolant.
    Jul 2018
    Wellington, Nevada
    Default Coolant filling
    Quote Originally Posted by Eviltwin View Post
    So your saying that it takes time to get from the fill spout to the tank?
    Jul 2011
    Mitchell, Ontario, Canada
    You really can't see the coolant level in the tank without shining a flashlight either through the filler neck or from the backside of the tank. I think you where seeing a shadow and mistook it for the fluid level. It appears you have now overfilled it.
    Jul 2018
    Wellington, Nevada
    Default Coolant tank
    Naw, not my first rodeo. I was using a flashlight and was jiggling the bike to see the fluid level in the tank. It was showing just below the cool fill level line. I'll look at it today to confirm where its at.
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    I've always wondered if adding a coloring agent, i.e. food coloring or similar would help and not harm......
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Bossier LoUiSiAna
    & there are sum funky bends in the hoses that can trap air follow the manual seeing in the bottle can be tricky sounds like you found away. Good luck hope all comes out satisfactory.
