Has anyone found a way to remove the start delay using the ECO button?
I know the new police model doesn't have it. It's a real pain to press the eco button & wait for clearance to start the F3's. Sometimes I think I could leave the key in it as most people won't know how to start it. If anyone has mastered removing the start delay--please advise--I have read the warning on the left service panel & while my memory isn't the greatest I don't need that 3-5 second delay.
Thank you kindly for any assistance,
Darrell
No short cuts.....😞
I have not heard of the eco button thing....on the older models you had to press the mode button. On the RS turn on the key hit the mode button then the start button and your off...the /RT's take much longer but the F3 were supposed to be faster...
Learn to live with it, it's a feature that BRP has decided that you will like.
No Way
Per BRP, no way to defeat it. It's in the software/Hardware. That was brought up at Spyderfest. New models that has been eliminated.
Start delay
It would not surprise me if BRP installed the start delay under the misguided assumption that we would all be using this extra time to read the safety card.
Darrell
I don't know what year your F3 is but my '16 F3 Limited has no wait time. I turn the key on, hit the mode button and press start. My baby's running.
2015 f3 no delay ether...hit the button start the spyder!
Why do you even have to Push a "mode" button. Never had a car, truck, bike or ATV (other than a BRP) that had an "mode" button and they all worked just fine. Has BRP ever given a reason for such a dumb control? It's really the only thing I don't like about my Spyder.
Turn the key hit mode start
As already stated, there is no delay, only the inconvenience of pressing the ECO/Mode button. Although I'm so used to it now I don't even really notice it.
Anyone who is thinking there is a delay may be waiting for the dials to go through their cycle before pressing the ECO/mode button and then the starter. You do not have to do this. As soon as you turn the key you can press the ECO/Mode button and hit the starter immediately afterwards. The bike will start even while it's finishing it's dial cycle.
At first I thought I had to wait for it to display the 'read safety card' message before I could press ECO/Mode to acknowledge it. However, one day I just pressed the button without thinking about it and the message was cancelled before it came up. I now do the key, button, starter procedure all within 1 second and it's up and running.
| 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
My F3 tells me to read my manual first. So I break out my manual, read it, then press the ECO button. Yeah right. That way, BRP is off the hook for liability. Same idea as "read the manual" engraved all over your Ruger handgun.
John F.
Tallahassee, FL
2015 Spyder F3 SE6, black
BRP Driver/passenger Footboards
BRP Adjustable Passenger Backrest
Blue Ridge Windshield
MRA X-Creen Tour, clear, clamp-on
H4 LED Headlights
F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
Easy Brackets
Leatherworks, Inc. 120 Special Slight Angle Saddlebags
Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
2-up rear shock
Idler pulley kit
just be glad there isnt a module somewhere that reads it !!!
[joyce & irvin toms]
I have a 2016 F3 Limited and I DO have to wait😡
Originally Posted by wengerda
I have a 2016 F3 Limited and I DO have to wait��
Why? What do you have to wait for? Have you tried pressing ECO/Mode straight after turning the key and then pressing the starter?
There's no need to pay any attention to the display and another owner confirms no delay on their LTD.
Okay maybe I am use to waiting for the screen to show the safety card info, later on I will try to push the eco buton and see if it starts. Thank you for that information.
You're welcome, I was the same but did it absentmindedly one day. Now I don't even look at the display to start it.
No, All F3 are wait free.
Turn the key on and as soon as the gauges sweep (this is also when the can am logo shows up on the color displays) you can press mode, then start. Its about 2 seconds from key on to start.
This works on 2016 and newer RT as well.
It's a stupid delay and serves no function as far as I can see.
Having said that, I've learned to live with it. I start the Spyder, and then put on my gear. By the time I'm done, I can hit the mode button and immediately start the engine.
It's still a stupid delay.
Did I say that the delay is stupid and foolish ?
Just my opinion. I could be wrong, and if I am, I'm sure someone on this site will let me know.
IBA #47122
2020 RT Limited Asphalt Grey
