Results 1 to 25 of 27
Thread: Rear tire
    Feb 2017
    Lodi, CA
    Default Rear tire
    I have been unable to find anyone who carries “non” BRP rear tire. 😬
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by moogully View Post
    Here's what use: https://www.tirerack.com/tires/tires...omCompare1=yes
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Faribault, MN
    I have been unable to find anyone who carries “non” BRP rear tire. ��
    Moogully, do you mean any local BRP dealer who carries a "non" BRP Kenda rear tire? You can purchase many oft recommended rear tires for Spyder's from Walmart, TireRack, Amazon, Ebay, and others as long as it's the correct size etc. My last list (for my '13 RTL) included
    General Altimax RT 43 in size 215/60-15Kumho Ecsta AST 225/50 R15 91H
    Kumho Solus KH17 225/60R15
    Yokohama S.Drive 205-55-15"
    Michelin Premier A/S in 205/60R-15
    Federal Formoza AZ01 All-Season Radial Tire - 165/55R15 75V (Sorry, this was my latest fronts, not a Rear as OP asked about.)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default BRP rear tire
    Like " DGoebels " has mentioned BRP dealers sell ONLY BRP tires ..... There is another " OFFICIALLY Labeled Mtc " tire for the rear of the Spyder ...it is made by Vee Rubber co. and it's called the Arachnid ....however it has shown to be even more inferior to the Kenda's ....very high rate of defective tires and mediocre response from the seller ..... at least this is what has been said from many on this Forum ...... Mike
    Default Only two, only two....
    As Mike mentioned there are only two tires stating for motorcycle use only. Kenda and Arachnids of which BRP dealers only carry Kendas. Many have gone to car tires of which there are many. Dealers will not install them. I have no complaints, have used Kendas with good results and currently have an Arachnid which is doing well. Lots to read up on here if you go to car tires....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Faribault, MN
    Some dealers will install non BRP specified tires. I just had a BRP dealer mount and balance my new (Federal Formoza AZ01 All-Season Radial Tire - 165/55R15 75V ) front tires, and mount and balance all three of my friends General Altimax's
    Safe Rides,
    IBA 70020
    Jun 2017
    Burleson,Tx
    Tireseasy.com great price 3 day delivery on federal tires for front.General Altima on rear.
    Dec 2015
    Oakley Utah
    Then you're not trying very hard. Every tire store, including Wal-Mart, carries car tires to fit the rear of your bike.
    There are TONS of threads discussing this on the forum.
    2014 RTL Platinum
    NorCal - Northbay
    Not true! You should have said, "Most Dealers" will not install them. Mine installed my Kuhmo Ecsta AST without even blinking an eye!
    Chuck
    Dec 2016
    Gold Coast, Australia
    I had a can-am dealership install the tires on my spyder, but I signed a wavier. Deanna
    I would not have signed the wavier. You are replacing the tyre with one of better construction. Kendra's are labeled M/C only to stop stupid people putting them on cars.
    Currently running Falken XE912 on rear.
    Cheers
    Frank
    Dec 2015
    Oakley Utah
    Stan Teske and his rear tire.jpg Try this. Guaranteed great mileage and long life.
    2014 RTL Platinum
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Re rear tire
    215/60R/15 General Altimax RT43 great rear tire Amazon.com got 13000 miles looks like new
    Vermont
    [QUOTE=moogully;1345452]I have been unable to find anyone who carries “non” BRP rear tire. 😬[/QUOT I am running the General Altimax RT43 ( 215/ 60 R15) on the rear, and I have 16,164 miles on the General Altimax RT43. Replaced the OEM (Kenda) in 2015.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Fearless View Post
    Then you would have had to take your tire mount business elsewhere. Why should the dealer accept liability for your choice of tire?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Me too.
    2014 RTL Platinum
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Might have a clearance issue
    2018 RT Anniversary , Brake pedal extended
    Northern Kalifornia
    Default New Kenda's ????
    Dropped by my dealer's showroom the other day and found several new crapenda's on the tire rack. Parts man said they just got them in recently. I looked at them with my hands and the sidewalls for both the front tire and rear tire were stiffer than 3/4" plywood. They were much different and heaver than the OEM tires that I took off my spyder. The tread patterns are still the same but the new Kenda's seem to be much stronger and stiffer than the OEM Kenda's.
    Northern Kalifornia
    Default Oh yea, but
    Quote Originally Posted by Ex Winger View Post
    Cut a little of the rear fender and get a wider swing arm and it should work.
    Harrington, Australia
    Thanks 2dogs.....that sounds promising for those of us who would rather have the dealer replace the rear tyre for whatever reason. I wonder if there will be any kind of announcement?
    HeliBars Handlebars
    Kenda Kanine rear.
    Houston
    We stock and install quality Yokohama tires on Spyders. Front and rear for the 15" sizes.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Northern Kalifornia
    Default Don't know.....
    I've heard (read) comments here that Kenda's have been improved over their famous 6/7k max life OEM tires. As sad as it is you can't 100% trust any dealer/parts person/service manager to be competent or fully knowledgeable about the product they handle. You may trust but you absolutely must verify. They'll BS you trying to make you think they know it all. There's an entire Britannica full of reasons why not to completely trust a dealership. Posters here are an excellent source for verification. I have to go to town in the next couple of days and I'll stop by the dealership and speak to the parts girl about the new tires. She's pretty sharp and if she doesn't know the answer to a question, she has the skills to at least find the answer. The spyder tech is most knowledgeable however they keep him sequestered in the shop away from the public. I'll add to this post or send you a PM.
    Northern Kalifornia
    Default Stopped by the dealership parts department.........
    I checked out the new Kenda's on the tire rack along with a couple of older Kenda tires. The older soft side wall types were all 14"ers. They were the front tires. The dealer didn't have any of the older Kenda rear tires to compare. All the tires were marked "J" as designates a car tire with a car tire bead. Also on the tires they were clearly marked "motorcycle use only'" and each one of them were marked 3 ply side wall. There was a very notable difference in the side wall stiffness between the older front tires and the newer front tires even though both were marked "J" and "3 ply side wall," The parts person did not recall exactly when the last shipment of Kenda's arrived but said it was last year sometime in late summer. All the newer stock of Kenda tires had very stiff side walls, so, maybe they got the message as some posters here have said they're getting better millage on their Kenda rear tires.
    Jun 2014
    ny
    Is that your front or rear tire pete?
    Northern Kalifornia
    Default No......
    That's one of Pete's trailer tires.
    Jan 2018
    Tennessee
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    I bet the ground clearance is good. Gas mileage probably not so good tho.
