Originally Posted by Farmboy
Not sure how the st's exhaust... if it has a 30 lb. cat or not but i can see if the wind blowing break fluid onto the cat, may have contributed to the rt's fire that was posted?
DOT 3/4 brake fluid will burn but it's not considered a combustible substance so wind blowing brake fluid onto the outside of the cat would most likely not ignite a fire.
Probably not, but it sure makes a mess. That stuff's corrosive.
That is does..... I guess I need to check the wife's ST to make sure the master cylinder is in good shape and possibly fab a heat shield.
I'd just wait for BRP to make one. And avoid riding it in the meantime.
...in the pink (Girls On Spyders)
check the spark plugs...my are white...running lean
#9 sparkplugs, heat shield around MS, computer reset
My 2013 Spyder RT-S Master brake cylinder is ok at 3,200 miles, but still added HP reflective heat shield around master cylinder; double wrapped #2 cylinder exhaust pipe and temp dropped to 152 deg. Putting in colder running #9 iridium plugs, with a computer reset from Len helped it to run richer with light black carbon instead of the white it was previously using the #8 plugs. (I also added a 2 Bros muffler before the computer reset). Len can advise your dealer how to reset your Spyder ST to run richer.
Added HP reflective shield over top of #2 cylinder to stop heat around left side & seat. Added Hp reflective heat shield to front & sides of gas tank, gas temp dropped to 128 deg, gas cap is now 116 deg.
Hang in there. Jim
Originally Posted by Netminder
You would think the engineers/designers at BRP would figure out by now that when you have a motor and exhaust enclosed in so much Tupperware, it is essential to control the heat under there? I think they better get things straightened out quickly as sales will drop if word spreads about dangerous heat levels on these machines! Hot to touch gas caps, burning Rt,melting master cylinders and hot seats are just not normal, I don't care what anyone says! I have owned a few bikes over the years and never had any of the heat issue that the Spyder is having. Luckily I have not had any with my 2012 RT, except a bit of a hot foot, but I wear good boots and it is bearable. But I am keeping my fingers crossed!!
Harvey at Spyderpops can cure the hot foot on the 2012 RT for a real low price, give him a call 501 627-4008
Cruzr Joe
I'm wondering whether anyone has thought of replacing that large black "cover" over the rear wheel with a grille...???
Cruzr Joe
Yes I have seen it. I have his bump skid, just haven't had a hot enough foot to put this mod on yet, but maybe soon! Thanks.
Sorry but we didn't spend $24K to avoid riding it...............
Dealer should take care of this ASAP!
I don't know what to tell ya... I don't want to sit and make payments on something that's suicidal to ride in this condition either.
But I can tell ya, suddenly losing your brakes will change your mind real quick.
At least on the GS there was/is a parking brake which would do SOMETHING. If not eventually stop you.
I recommend calling BRP twice a day and asking for status.
File a complaint via NHTSA.
Call your dealer multiple times a week depending on how much you like them.
Call your insurance company and verify with them if they'll cover your medical expenses if you ride knowing that your brakes might fail any minute.
If you're comfortable with the responses you get from all of the above, ride on! It's completely up to you. I just recommended being safe because I would hate to see someone get killed because of this huge, obvious and dangerous flaw that I'm sure showed up in BRP's testing and went ignored (I'm sorry, de-prioritized.)
Yes, I'm frustrated. 3 weeks of the best part of my riding season so far. I expect it'll be months before they put a bandaid on this and another year before they finally fix it like the other dangerous design flaws in previous models.
Reason: added extra venting. no pun intended.
mine is parked in our m/c barn...I will not ride it until fixed...I enjoy life too much
I am confused about about what you said. You say you suddenly lost your brakes. Do you mean that suddenly you had no brakes and you could not stop or you are surprised you had a brake problem. From your pictures it is clear that the plastic melted to the point that the reserve brake fluid for the front brakes leaked out. It appears that fluid path for the reserve fluid for the rear brake is intact and the rear brake should have worked as it should. The front brakes should have continued to work as well but air would have entered the high pressure side of the master cylinder after a couple of uses but still worked in a degraded level.
If I am in error and that is not correct, please explain what I am missing.
What exactly where the other dangerous design flaws in previous models you speak of?
Did you personally experience them?
Carl
