Results 1 to 17 of 17
    Apr 2017
    Queensbury, NY
    Default Let's Talk Horns....
    I've found discussions here on SL on just about every conceivable Spyder (and other) topic, but don't recall any discussion about horns.
    FWIW - I find the horn on my F3T pretty anemic. I'm not looking to wake up the world and I'm not looking for something obnoxious, but I think getting a louder horn would be a worthwhile safety upgrade.
    So, does anyone have any horns to recommend?
    Thanks.
    Bert
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    Default Bad Boy
    Found the same about my RS. We had the Bad Boy on W's RS and my Beemer. Just the right loud for us. Arounded $50. Probly carried by a sponsor or three here. Can install with relay, tho I did not.
    Enjoy your ryde!!
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    Sep 2014
    USA
    been using a WOLO horn. Lots better than stock. Bolts right into stock location
    Default Interesting....🤔
    Don't know where you looked but there has been a lot about horns...Stebeil, Wolo Bad Boy, and some crazy mods that will blow you backwards when honked...
    I had the Bad boy but found adding a low tone to the oem horn worked better for me and louder for sure.I did mount it outside the body works for better effect. The F3 is pretty wide open. I just spliced into the exsisting wiring to the oem horn...Hold on I will get a picture....
    Stebel Nautilus...
    The Wolo Bad Boy is a just a copy...
    Jun 2017
    Hackettstown NJ
    Default 131 db
    Tricled has one............I have it realy scares the ......…
    https://www.tricledusa.com/product-p...h-safety-relay
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Anyone have any experience with one of these?
    https://screaming-banshee.com
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Aug 2012
    CO
    Default Horny topic? ;)
    We have the Stebel Nautilus on our GS. Mounts neatly under the tupperware next to the stock horn. On our street bikes I replaced the tinny stock horns with Denali Sounbomb minis; because of their small size and lack of air reservoir. http://www.twistedthrottle.com/denal...otorcycle-horn
    JLohPhotos
    2008 GS , Millennium Yellow
    Active Member CrashDavis's Avatar
    Jun 2017
    Niceville, FL
    Quote Originally Posted by BoilerAnimal View Post
    I have an earlier model on my Vic, but the current works the same way, just less parts. It's as loud as the others and it gives you the option to not be loud if you want. A quick press and release gets you the not so loud. Hold the button for more than a quarter second and you know it's there. You also have the option to tie it into your headlight and make it flash.
    The product is great, the only reason I haven't put one on my Spyder is I've been too lazy to do it yet.
    2017 RT Limited
    Bossier LoUiSiAna
    Like this?IMG_7622.jpg &the required air tankIMG_7626.jpg don't just scare them go ahead & BLOW out of the way
    fyi Spyder Attitude at On Da Bayou
    Here's the trumpet air horns I installed on my 2013 RT. http://www.spyderlovers.com/forums/s...l=1#post850017 I put the same horns on my 2014 as you can see in my sig pic. The big difference was there is plenty of space behind the left grill on a 2014 to install the compressor. The relay for the compressor power is connected to the OEM horn which is still in there and functional. The horns are very loud, and IMO look good where I have them mounted.
    Sep 2008
    TX
    We have dual Wolo air horns mounted on our F3's, exposed, one on either side. Used a single 30 amp relay as the OEM horn button would not carry the amperage; the wires at the horn would but not the CanBus plated flex circuit in the handgrip. They get attention. The Stebulis is loud but 2.5X the cost.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Apr 2013
    Michigan
    I had a Stebel Nautilus on my RSS (sold it today). It was an easy install, never had any problems with it, and it was a LOUD honker!
    I'll certainly consider putting one on my 2018 F3 S when it arrives!
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Wolo has 2 air horns, the bad Boy, model 419, and a deeper toned one, model 619, that sounds like a cross between a semi and a tugboat.
    john
    This is the one that you REALLY want...
    :roflb lack: :bowd own:
    May 2017
    Tampa,fl
    Jun 2017
    Hackettstown NJ
    Default WOW
    I might need to upgrade
