Can you answer me this please ??
2015 RT-L
I replaced the 3 original stock OEM kenda's at 6,000 miles --- they were toast !! past the wear bars on all 3.
My dealer replaced the tires :-
Rear -- Kumho Ectsta in the stock size.
Fronts -- Kenda's in stock size (dealer would only use Kenda's and I was short on time to order my preferred brand)
Then came a 3 week trip where we put 6,000 + miles on the new tires.
I looked at the tires this morning and the fronts are looking almost new !!
Why were the original Kenda's toast after 6k and the replacement front Kenda's still look like they can go another 6k ??
Is Kenda making a better product now or are the originals a cheap BRP placement ? --- to save on cost maybe ?
Don't get me wrong -- this isn't a complaint
This IS an interesting question...
I got over 18,000 miles out of the OEM front Kenda tires; the rear was shot at 5,700 miles.
They were playing around with the tread compounds back then: you might have gotten a softer set up front also?
TIRE WEAR THEORY
Even tho I totally dis-like Kenda's ..... I will admit that when used on the front can get decent mileage ( not as good as car tires, but good enough )...... The only way this will occur is a near perfect front alignment .... if your alignment is off they will wear early, sometimes very early..... I can't account for your tires tho..... Mike
That is weird since your Spyder is a 15 and they quit using the soft compound around June of 14. Too bad you don't have the original tires so you could check the born on date on them.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Probably same reason my Honda had bad tires when new too
Originally Posted by HayRog
2015 RT-L
You know, I bought in 2011 a new Honda Civic. Those tires only lasted me about 40K miles. On a new car no less! Sheesh! Since then my tire wear has been far greater. I believe it's their way of cutting costs on new units. Sad if that is true though. Especially for what we all pay for these vehicles.
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
Gotta say...
There must be more to the problem on your tires...pre compound change on my RS aggressive ryding I got 33,000 on the fronts and 19,000 on the rear. My RS is manual. I got the same miles on the second rear which was after the change back to original compound. I am currently on a Arachnid rear ...I find the model and type you ryde the roads you ryde on your location and the weather have a lot to do with tire wear....
20160324_085157.jpg this is my kenda when it hit the wear bar....still gripped the corners well....
I know it may be hard to admit, but you know you were in that honeymoon stage on that first set of tires. Twisting that throttle and leaning into those curves and turns was exhilerating.
Now, you've slipped into chill mode and that rubber just tends to hang on longer.
You really may have a point there .... hmmmm..
Something I never thought to do - duh. I should ride down to Vegas for a squared away one day. Even though the dealer said the alignment was good.
2016 F-3
I have about 5300 on my stock rear and it is down to the wear bars. Might get another 1000 out of her but I doubt it.
Be SURE you know the difference between wear bars and hydroplane-breaker bars.
My rear OEM Kenda gave me 17,000 miles. The fronts look to be only half-gone now at 37,800 miles.
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
Photo of breaker bars and wear bars.
Gotta photo, never heard of hydroplane breaker bars?
2021 Marsala Red Metallic RT Limited
Not sure about motorcycle tires but OEM tires are different than replacement/aftermarket tires of the same make and model.
OEM tires are designed to meet certain specific targets required by the car maker for that car, such as wet and dry handling, noise, ride comfort, etc. Aftermarket tires are more generalized for multiple car application and can even have a different compound that also affects mileage, wear, noise, etc.
If this is the case with Kenda tires, that might explain some of the difference between original and replacement tires.
Just a thought.
