Results 1 to 8 of 8
    arntufun
    Guest
    Default GS/RS Trunk removal and BajaRon Anti Sway Bar install
    This video will show you how to remove the front trunk on a GS/RS.
    This video will show you how to install the BajaRon Anti sway bar on a GS/RS. Watch trunk removal video prior to viewing this.
    GOS Founding Member (Girls On Spyders)
    Apr 2011
    Arkansas
    Thanks, Randy. This is very timely! There's a thread on the GOS FB about this very subject right now. I just shared a link to this post.
    Randy,
    But I really think that you should have your "lovely assistant" featured in the videos...
    Jun 2013
    Southern Oregon
    Default Sway Bar installed
    These videos really helped me to visualize the frunk removal and sway bar installation. Once I had watched them, the installation was easy. Thanks for the post!
    Mike in Southern Oregon
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Quote Originally Posted by arntufun View Post
    Thanks, this was VERY helpful, the only thing that I would add is that if you are going to replace the links, you would be well advised to remove the 2 "panels" that are over the top of the links. #8mm screws use a drill/driver. Makes life easier.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Registered Users donkes's Avatar
    May 2015
    VA
    Randy,
    Not a bad idea
    May 2015
    VA
    the video was very helpful. thnx
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Randy,
    Re: This video will show you how to . . .
    I used both of those videos when I installed my sway bar. Most helpful. And I saved them to post whenever anyone asks about doing so. I spent way too much time trying to find them on here when people would ask; simpler to just save them.
    I still do not understand why these are not a 'sticky' for future reference.
    Thank You so much,
    Jerry Baumchen
    PS) You and finless (Bob) deserve some type of award for all of the work you have done in making a number of videos.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
