Results 1 to 19 of 19
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default What size wrench to remove drain plug
    I looked pretty much all over this board. Ton's of people talk about changing oil. Not one mention what size tool is needed. Is it a Torx, an Allen , a socket? One suggested using a Allen/Torx. What the heck that means? I need to do my second oil change (first done by dealer to the tune of $457.00) Ridiculous. I'm doing the second oil change myself. Just needs to know exactly (not may be this or that) if it is a Torx or an Allen and what size for each drain plug. I do know that the filter requires a 36MM low profile socket. I looked in the manual. They're great at telling you where the plugs are but not a word about what tool to use.
    Anyway, help is appreciated.
    2018 RT Limited "Blondie"
    Bossier LoUiSiAna
    This may help:
    https://goldplug.com/
    remember there's more than one plug & filter on some.
    The crankcase plug wrench a Torx T45 bit and the clutch cover, a.k.a. transmission plug, is a 6mm Allen bit.
    Torque specs, if you are inclined to use a torque wrench, which I always do:
    Oil Sump Drain Plug torque = 21 lbft , +/- 1 lbft.
    Clutch Cover Drain Plug torque = 15 lbft, +/- 1 lbft.
    Oil Filter Cover torque = 18 lbft, +/- 2 lbft.
    Sep 2016
    clark county indiana
    Default careful now
    sometimes the oil guys , tighten the heck out of the oil drain plugs , might need to go a little clock wise and then counter clockwise ( right then left ) , but try and break the plug loose , before you put a heck of a pull on the plug ! ( might strip the wrench openings where you can`t get it to spin out , just a be careful warning only ) mine on last cycle was a bit tough ! ( another idea , watch you tube videos on oil change can-am spyder , gives a point of view , where the oil filter on the s-e models are a bit of a trick ... )
    Apr 2018
    Thank you all. Got the info I needed.
    Dec 2015
    Oakley Utah
    True. Best reason I can think of to do your own oil changes.
    2014 RTL Platinum
    Oct 2014
    Fort Mill, SC
    This may help:
    If you are going to do your own oil changes for now on, invest in Goldplugs. The stock plugs will eventually give you problems down the line.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Apr 2018
    Default Drain plug
    I do have the Gold Plug (not installed yet). I just needed to know what type of wrench to remove the old plugs. I do now.
    Crankcase T45 Transmission 6MM Allen and 36MM filter.
    Someone suggested to go to the Gold plug website. Well, this site does not tell you what wrench for removing the old plug. My question was very specific but still some people just gives off the wall answer. Sadly it happens enough on this site.
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by Bigmo View Post
    I'm sorry, I was just trying to help. Next time you ask a question, I won't.
    1998 Honda Valkyrie
    US Navy Veteran
    Sep 2016
    Default good luck
    good luck , no need for more information, to someone who is about to do their own 1st oil change ...
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    You might want to consider a few moments with a Dremel tool. Enlarging the openings around the drain plugs really helps reduce the mess that sometimes spills out those tiny openings.
    Even though my suggestion doesn't specifically answer your question------ It was a suggestion that isn't "off the wall" and helps some of us do cleaner oil changes.
    Lew L
    2014 RTS , Circuit Yellow
    Apr 2018
    Quote Originally Posted by Grandpot View Post
    Don't be offended. I was just trying to get some answer. I am new at the Spyder and may ask more questions. Of course, there's always GOOGLE. But why, since so many, if not all on this board, may have a better answer than Google. Practice and experience makes good teachers and some of us do need the help.
    So, if you felt offended, I apologize... Have a great day.
    Apr 2018
    Default Drain Plugs
    Quote Originally Posted by Lew L View Post
    Lew L
    I do like your suggestion. I just got a lift from HF and tried it yesterday. Works great. Lift all 3 wheels and keeps it balanced. It will allow me to look under and make the opening wider.
    Thanks for the suggestion.
    Oct 2014
    Fort Mill, SC
    No worries; we're good. Some of those extra answers sometimes will answer a question you didn't know you had.
    1998 Honda Valkyrie
    US Navy Veteran
    Mar 2015
    Lightbulb Jack stands
    ANd--------
    Please use sturdy jack stands and maybe a large block under the back wheel. A only falls on you once.
    Feb 2012
    Spring City,Utah
    So here is another answer to a question you didn't know you had, If you look on the HF lift you will see 4 small loops ,one on each leg.You can use them to use a tie down to also keep your Spyder steady.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    SoFlo
    Your call, but consider inserting the correct Torx bit into the drain plug and ensuring the fit is proper for the full depth, tap the Torx bit fully into the female Torx on the drain plug itself.
    Worth doing on the 6mm Allen also.
    As a side benefit, the light impacts can help free the drain plug.
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    As I'm reading through the forum I bookmark all threads that are or may provide valuable info
    http://www.spyderlovers.com/forums/s...Change-Worries
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Feb 2018
    NorEastern, Washington
    Or maybe not: http://www.spyderlovers.com/forums/s...ped-drain-plug
    Regards,
    Don
    2017 F3T , Triple Black
