Results 1 to 10 of 10
Thread: Sway Bar
    Active Member Tyris's Avatar
    Dec 2016
    Iowa
    Default Sway Bar
    Does the RT Limited come with a swaybar or is there not one there to begin with? If there is one, anyone have a pic of the two side by side, not sure what the difference is. New owner of course.
    2016 RT Limited , Black
    Harrington, Australia
    Quote Originally Posted by Tyris View Post
    Tyris, it might just be me, but that question doesn't appear to make any sense. Yes, Spyders have a sway bar, but "a pic of the two side by side"? The two of what?
    HeliBars Handlebars
    Kenda Kanine rear.
    Jan 2015
    southern WI
    I think he wants to know, if there is a stock one, what's the difference between BajaRons bar, and the stock one. BajaRons is heavier built and supposedly stronger to help prevent "roll" in the corners, and other benefits too. I still haven't had a chance to try mine since replacing it....but I did the replace in my 2010 RT I had and it did make a difference
    2016 RTS , Pearl White
    Dec 2016
    Iowa
    Quote Originally Posted by Mazo EMS2 View Post
    Precisely, just trying to figure out if the spyder that I have has a swaybar already, what I'm getting by getting another one. I thought a side by side comparison between the stock swaybar and the Baja swaybar would give me a clue as to if its worth spending my money on or not.
    I'm not cheap, but I am somewhat "tight" I see people say that it improves the ride but seems that a lot of people stick with the stock bar as well. So kind of on the fence yet.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    ALL Spyders come with a sway bar!
    No pic but the Baja is about twice as thick.
    The new links are metal and move as they should; the stock are really tough to move.
    Believe the 1000s that have made the switch.
    You will not regret it and the easy it brings to manuevering with a proper alignment of course!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    ...I'm not cheap, but I am somewhat "tight" I see people say that it improves the ride but seems that a lot of people stick with the stock bar as well. So kind of on the fence yet.
    I consider myself frugal which my wife translates as World Class Cheap! Nevertheless, I popped for a BajaRon bar installed by the dealer as part of the OTD package. Looking at an OEM bar and Ron's you will ony be able to see the latter is larger in diameter but you can't tell just looking how much better it will make your Spyder handle. Life is short, pop for it and have more fun!
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default re
    The ends - are "metal" ? Not according to Baja Ron - the ends are now aluminum.
    Speaking of BajaRon: He's the guy who is most likely to have some side by side comparison pictures of the bars...
    See if he'll post them for you!
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Quote Originally Posted by Many brands View Post
    Aluminum is a non-ferrous metal.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Yeah, I thought that might have been it, Mazo, but there was absolutely NO mention of Bajaron's stabiliser bar anywhere in the initial post, which is why the question was so confusing.
    HeliBars Handlebars
    Kenda Kanine rear.
