Results 1 to 5 of 5
    Member Garf's Avatar
    Oct 2017
    Hartland, Michigan
    Default Windscreen Modification
    With the unusually hot summer we are having here in Michigan, I find myself longing
    for some extra breeze over the top of my 2017 RTL's windscreen.
    Even in the full down position there isn't much.
    Has anyone had their STOCK windscreen shortened by say 2 inches? And who would do that type of work?
    When colder weather comes, I can always raise it up to block the wind.
    Guess I'm looking to have my cake and eat it too!
    Thanks for any sugestions
    Gary
    Gary
    2017 RTL Asphalt Gray Metalic
    Sep 2016
    Chillicothe, Oh.
    I have trimmed several shields over the years with good results. I use a good quality masking tape and apply three layers. Mark the shield where you want the cut. I use my jigsaw with a fine tooth blade and then sand the edge with a fine grit sandpaper. Take your time and make sure you have enough tape to protect the shield. I have done them on and off the bikes.
    Oct 2017
    Hartland, Michigan
    Great suggestion, I can do that!
    Gary
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    Did a similar thing on my 2014 RT, cut 3" in my case. I'm short and even with the shield all the way down, I was looking through it. This, as you say, allows airflow in the down position and when raised up blocks air and I could still look just over it ! Try it you might like it.
    Navydad did exactly what I did, with one exception. I ran a piece of chrome door edge molding around the top of the windshield after cutting. Kind of finished it off.
    Quote Originally Posted by Garf View Post
    Gary
    Current: "Scarlett", 2017 Can Am  F3-T, SE6, Intense Red Pearl.
    DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, RonJon swaybar and billet links, Roadster Renovations vibration dampener, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Interesting....maybe I could eliminate the "recurve" in my shield after all...
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest
    Givi Saddlebags and Top Case
    BajaRon Swaybar
    Tricled Wide-Vu Mirrors
    1996 Yamaha Virago 750 (Vera) - garaged for now
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
