Sorry to have to say, when leaving Fort Lauderdale yesterday morning, I got 3 Limp modes within 45 minutes while running to get on the Fl Turnpike for the ride home. Luckly I did not have any problems on the turnpike but I did not turn off the bike to get gas for the return home.
Hopefully, next week parts will arrive and I will get all fixed up. This Limp stuff is getting OLD.
PS:
I was informed that I had two throttle bodies installed at WPS in Clearwater, so the count is 5 throttle bodies, 1 OEM, and 4 replacements. However I did not recall the 2nd one at WPS maybe they went ahead and installed i while the spyder was in for service one day.
You have a large set of To get on the TP knowing limp mode is going to strike
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
PS:
what parts are being replaced now?
... so the count is 5 throttle bodies, 1 OEM, and 4 replacements.
PS:
Forrest: It is very easy to check on how many throttle bodies have been replaced. Ask the sevice writer to print out your complete warranty record. He can do this in a matter of seconds. It will show what has been done to your Spyder under warranty no matter where the work was performed.
Thanks Walt... I will ask the next visit.
I think it will be informing to me just what they have done under waranty and not being told when it was serviced..
Justin is a great guy...
He's right Forrest. I had, Jason, at Seminole Power Sports in Sanford, print me up a complete service record on my spyder.
Chris
