Page 3 of 3 FirstFirst 123
Results 51 to 65 of 65
  1. #51
    Very Active Member JimVonBaden's Avatar
    NoVA
    Quote Originally Posted by philkin View Post
    Interested in obtaining the Heated Grips & Usb switches. (source)?
    Grips from here:http://www.ebay.com/itm/172289050588...%3AMEBIDX%3AIT They are a dealer, and he has great customer service.
    The USB was here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The light switch was here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Perfect factory direct plug on the switch. I used the hot and ground from the dummy plug for the USB. Red and black wire came out and plugged right into the USB.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
  2. #52
    Jun 2015
    Tucson
    Quote Originally Posted by JimVonBaden View Post
    Unfortunately the Stebel horn would not fit where the stock one is, though it worked. So I installed a louder conventional FIAAM High horn.
    Bolts right in, much louder.
    May I ask What type of horn and where did you purchase it. Thanks
  3. #53
    NoVA
    Quote Originally Posted by SpyDnAZ View Post
    Knock off Fiamm I got from AutoZone. It comes in a high low set. I used only the high. You can get them at Harbor Freight as well.
    Jim
    2013 ST-S (wife's)
  4. #54
    Jun 2015
    Tucson
    [QUOTE=JimVonBaden;1216057]Knock off Fiamm I got from AutoZone. It comes in a high low set. I used only the high. You can get them at Harbor Freight as well.[/Q
    Thanks for the information
  5. #55
    NoVA
    Saw an interesting USB on another post, so I thought I would try it. Plug and play like the one I used:
    But the new one has a volt meter, which I wanted to monitor when I have all the accessories and heated gear turned on.
    Plug and play, and works perfectly.
    Also note the GPS mount.
    Jim
    2013 ST-S (wife's)
  6. #56
    Active Member Marcy's Avatar
    Leesburg VA
    Wow Jim, all the mods to your wife's bike is awesome. Are you sure you bought this for "her"? Can't wait till it warms up and she can come ride with the club.
    Marcy
    2019 F3T , Blue
  7. #57
    NoVA
    Quote Originally Posted by Marcy View Post
    Marcy
    I have more miles on it than she does, but she doesn't like the cold. That will change in the spring.
    Jim
    2013 ST-S (wife's)
  8. #58
    Leesburg VA
    Jim
    What are these called? I have heated grips but the tips of my fingers get so cold. Thanks.
    Marcy
    Prepping for winter riding!
    2019 F3T , Blue
  9. #59
    NoVA
    Common name is Hippo Hands, but they come from many different places.
    https://www.rockymountainatvmc.com/p...k+winter+muffs
    Jim
    2013 ST-S (wife's)
  10. #60
    Leesburg VA
    Thank you. Order them and Firstgear Thermo Suit, can't wait till spring to ride. It's really good for my mental health. :-).
    2019 F3T , Blue
  11. #61
    Sep 2008
    Yorktown, VA
    Jim,
    Could we get an update on the hard saddle bags? How are you and your wife liking them?
    Thanks,
    Bruce
    Yorktown, VA
    '08 Spyder GS
  12. #62
    NoVA
    Quote Originally Posted by bwbarnes View Post
    Jim,
    Thanks,
    They are holding up great and look good. She rides to work several times a week, and uses them daily.
    Jim
    2013 ST-S (wife's)
  13. #63
    Jul 2017
    sarasota, fl
    @Jim Von
    the bags lights in your first post are awesome.
    I have the same bags and would like to have the lights on my bags work like yours.
    How did you connect the bag lights to get the dual function?
  14. #64
    Sep 2008
    Yorktown, VA
    Thanks for the update Jim. Looks like I'll be ordering a set for my '08 GS.
    Bruce
    Yorktown, VA
    '08 Spyder GS
  15. #65
    Default THE MUTAZA HARD BAGS
    ....I have these also .... I believe Warlock had a problem with the lock/hanging system ..... one of His bags came OFF !! ...so He devised a method of preventing this .... I can't remember exactly how He did it .... but I came up with a different way to solve this problem .... to prevent the bags from EVER coming OFF by accident ..... I welded a NUT on the inside area of the mounting bracket ..... A bolt is now threaded thru the inside of the Bag into this NUT ..... after you open the bag you must remove the Bolt in order to get the Bag to release ..... The Bolt prevents the latch from EVER coming loose .... Mike
