bleeding brakes with vacuum system
Has anyone successfully used a Mity Vac bleeder or similar system to bleed the brakes on the Spyder?. If so, what would be the proper bleeding sequence?
[QUOTE=Bob Denman;651076] Solution? I'd hook a Turkey baster up to the bleed valve (with it's bulb fully squeezed and compressed)
Open the valve, release the bulb, and it'd pull the fluid down through the system slicker than snot!
QUOTE]
Bob, sounds reasonable, but will you test it out on your spider and let us know if it work?
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I use a Mity Vac on my bikes but the Spyder doesn't have enough mileage yet. I'd recommend downloading one of the service manuals so you can have the bleeding instructions at hand as there are about 5-6 pages of instructions. IIRC you need to disconnect the battery when bleeding so BUDS won't go into alarm for low pressure.
JT
Well ????? danger,,,, danger,,,, danger,, ID 10 T is approaching..
"ID10T" is my driver's license number!
You wont loose your radio preset disconnecting the battery.
JT, I always read if you do your own break work (like flushing, etc) you have to have buds to clear codes?
Does unhooking the battery actually work?
Bob
Bob
Bob,
I've not done it on my Spyder yet, I just did a quick review of the process in the service manual and it does say to check pressure with BUDS hooked up so I assume if you check pressure with the battery disconnected you won't trip the BUDS Nanny. I'm not sure what would happen if you pump the pedal with the battery connected and no pressure. One thing for sure if the battery is not connected BUDS must fall asleep after any caps run out of juice.
JT
I have always done my own break jobs on most my cars. When the time comes I sure would like to do it on my Spyder. Mechanically it does not look hard at all.
So if you ever do it yourself and it works, it would be great to write it up so those that want to save money can
Thanks!
Bob
Thanks!
Bob
It will be 8500 miles from now for me...
JT
...in the pink (Girls On Spyders)
Mark replaced my pads and bleed the brakes on my 2009 RS...we had to go to dealer...hookup to BUDS...$50....but if we ever get the ST back on the road and to the point that I need brakes...we'll try to unhook battery and see what happens
#IamARyder #RideASpyder #CanAmSpyder
Bleeding Brakes
I just changed my brake fluid and bled the vcm.As long as you don't turn key on you won't get any codes.Every thing works perfect.I have a 2008 gs
Can you amplify on the procedures used? Some of us have been tempted to give this a try but are hesitant. Did you start with a certain wheel and work your way around? What tools?
Any info you can provide will be apprec.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
2008 GS.....PE # 2888
Bleeding Brakes
I used 1 friend 1 quart dot 3-4.I sucked the old fluid out with a turkey baster then filled it up with new fluid.We started on left front stuck a piece of clear tubing over bleeder valve my friend worked the bleeder while i worked the brake peddle.We pump until we got clear fluid.We then did the right front then the back all the same way.Just be sure bleeder valve is closed before you let brake peddle up each time.The vcm is hard to get to, went in on left side pulled left panels off to get to it.The bleeder valve is on top it is hell to get clear tubing over bleeder valve.It would have been alot easier to take the trunk off but it can be done without it.Be sure to keep fluid near full when doing it you don't want to get air in system.I
used just about the whole quart,took about 1 hour 1 1/2 we had to stop and drink a few shop supplies.Its easy to do just watch what your doing.
Thank you! I am saving this post until the time comes!
Bob
I have disconnected my battery several times - no problems
I have 1 2011 RT SE5. I have not had to bleed the brakes, but disconnecting the battery should not be a problem. I have disconnected mine several times to add relays, switches, etc. No Codes and nothing needed reset.
When all is said and done......well it must be time to ride~
2 Stricklands, Steve & Barb
2011 RT AC, SE5
Trailer for Travel and/or Golf Clubs
Power outlet up Front
Floorboards
Voltmeter replacing old gas gauge
Oil Pressure gauge replacing old temp gauge
Turn Signals on mirrors
Just reading the service manual this morning and like skeetshooter did the bleeding sequence is:
Left Front
Right Front
Rear
VCM
They have you do all kinds of things and some I don't understand and some make sense:
remove front wheels
remove the calipers and position bleeder at highest point
detach lift cylinder and passenger switch from seat
unplug low pressure switch connector and brake light connector
detach brake fluid reservoir and move to outside the footrest
Ah here is the note: the previous steps are required for the hoses to run completely down toward the master cylinder.
Then they go into installing clear hose on bleeder valves and bleeding the brakes...
JT
... You do the Hokey Pokey, and you turn yourself about...
Left Front
Right Front
Rear
VCM
remove front wheels
JT
I just read the manual. I think the sequence in removing the reservoir ios so you don't spill brake fluid on the plastic
When I took my 2011 RS-S SE5 for the 14,500 mile maintenance. The tech said that he had a better way to bleed the brakes. When I got the bill to pay there was a note that said there was a problem with brakes and I had to pay $500.00 more to have it done the right way. I put my Spyder on the trailer and took it to another Dealer. The Dealer that tried to screw me over is no longer in business. The power of the Internet is great.
Mike
I haven't done my spyder yet, but there is no reason I am aware of that a mity-vac wouldn't work. They aren't that expensive if you shop around, you don't have to have anyone assist you with the job, and you can use the same tool to bleed/flush the brake systems in your other vehicle. A vacula works even faster but costs a bunch more.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
