how to replace fog light bulbs
Both fog lights/blubs burned out 3 weeks apart on my 2014 RTL. Need to know how to replace blubs, will I need to removed the front nose.
You'd be surprised at how much you can learn on Youtube.
The right one is the easy side; not so the left.
Good information
I’m replacing my headlights and fog lights this Saturday. I’ll take any help I can get ..!! I wish these machines came with led lights ..! They should have for what we paid .. (in my opinion)...!
2016 RT-Ltd
Bajaron swaybar
Spyderpops trunk light
Elka stage 2 front shocks
Extra longbrake pedal
brake modulator
Rivco dual flag holder
with American and Texas flags
Lamonster Magic Mirrors
missing belt guard
Lamonster led fog lights
Baker air wings
2019 Silverado Duramax dually
2019 Cyclone 4007 toyhauler
Rivco brand footrest
spydermanexhaust.com exhaust
I doubt this will be much help. It only shows the right side, which is relatively easy to access. What is needed is instructions on replacing the left fog light on an RT, which involves; a) really skinny strong hands or b) removing the frunk or c) removing the air intake tube.
Maybe a video about removing the frunk would be most appropriate?
Meanwhile, I found these written instructions from an earlier thread; http://instructions.brp.com/content/...mber=219400137
2014 RTL Platinum
SpyderLovers Sponsor
Patience
The trick is a 18” long #2 flat tip screwdriver. Slip in, twist, remove cover. Work cover out. Now trim 1/8th” off the bottom tab, following the curve. Replace bulb, replace cover. We use a 1” diameter wood dowel about 18” Long to pry the snorkel out of the way.
Joe Meyer
Thank you Joe for the information..!
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
I'll have to try that one next time!
2014 RTL Platinum
Band-aids are usually required to repair the knuckles of the installer.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
You can move snorkel enough without removing trim panel from around fog lights?Just did headlights,haven't buttoned up yet but thinkin I need to return the fog bulbs!Just not up for pulling frunk and whole front end...
nope, leave the trim alone. Use a broomstick, pry the snorkel out of the way to reinstall the cover. Get a helper, it is much easier! Trim 1/8” off the tab on the bottom, goes on much easier! Take your time, it will go on. Or, meet me in Texas hill country. I’ll put it on for you! I’m leaving for Texas Sunday morning. I’ll have my phone on. Call if you need me. Joe
Joe Meyer
Took a whole lotta time and tryin but it went!While trying to put cover back on I just kept tellin myself"It came off,gotta go back!"Suddenly you hit the harry potter spot and it falls together!Still,hoping I never have to do it again!Thanks all for the help!
