Results 1 to 7 of 7
Thread: Belt tension
    Jul 2016
    Finland
    Default Belt tension
    Greetings from Finland
    What is the correct belt tension,here are so many different values?
    The bike is Spyder RT SE5 2013 .
    For the measurement I have Gates 91132 Krikit II V.
    Markku
    Default Well....
    I see most running from 160 to 200 but as a rule of thumb you should not be able to twist the belt 90°. It's my understanding the loose is better all around...
    Quote Originally Posted by Markku View Post
    Markku
    Read my post here: http://www.spyderlovers.com/forums/s...=1#post1132712
    It is part of this thread: http://www.spyderlovers.com/forums/s...+tension+range
    Basically anything from snug to tight that does not cause a vibration at your favorite riding speed is OK!
    It's good to see a post from someone from the country of my heritage. Welcome!
    Jul 2016
    Finland
    Hello
    Thanks for the reply, I had read those messages, but I ensure this issue.
    I build the belt stabilizer just in case so that there will no to be the belt vibration but what is the right force what the roller presses the belt.
    The stabilizer should to be below the belt,a bit like Baker Built stabilizer.
    During the winter it is a good time to outfit the bike.
    The parts are not expensive in USA but if I order the parts to Finland it comes in addition the freight and it is expensive, and here I have to pay the customs in addition,therefore I thought to build the stabilizer itself.
    Markku
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Hello
    Markku
    I have the roller pressing up onto the lower run of the belt with 10 - 12lbs on the scale that was provided by SmoothSpyder.
    I also have a Krikit reading in the centre of the upper run of the belt of 180lbs, the Spyder sitting on the floor with all its weight on the suspension.
    Mine is an '08 GS though.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Active Member Bike-O-Din's Avatar
    Apr 2012
    Cross Junction, VA
    Default Help is on the way
    I reached out to Markku via PM. I have an original SmoothSpyder that I never installed. I now have the newer BRP version and do not need the SmoothSpyder. Jim at SmoothSpyder helped me gather the documentation that I misplaced, and some install pics and was very quick in responding.
    I am sending my SmoothSpyder to Markku as a gift so he can avoid the customs hassles. We have to help our brother Spyder riders whenever we can.
    2011 RT-S , Silver
    Jul 2016
    Finland
    Hello
    I am very grateful for Bill, and now just waiting for the package, and constructing my bike in winter evenings.Now I am building the Highway Peg.
    Markku
