Results 1 to 12 of 12
    Henderson, NV
    Default 'Patent Pending' Molecular Color Adhesion Process for F3 Frame Caps
    Alright maybe not 'patent pending' but you did click.....
    I had to take a trip to Lowes yesterday so I picked up some loctite and spray paint. I scuffed up the caps with some steel wool, hit em with some water, then the air compressor, then a microfiber cloth and then the spray paint. I let em dry overnight and the end result is:
    Before:
    After:
    I guess you could pay $129 for the chrome ones from BRP or $160 for the IPS caps. I chose to spend under $13 and I dig the results.
    They look VERY nice...
    Nice--and did not cost the proverbial arm and a leg.
    May 2014
    Texas
    Looks good. Could have tried PlastiDip. I did some PlastiDip work on my street glide and loved it.
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Quote Originally Posted by xBobbyx View Post
    I was thinking the exact same thing.
    Default Well done..!!
    looks great. I think plasti dip would not hold up as well. Good choice nice work...
    May 2014
    Texas
    I used PlastiDip on my 2011 Street Glide. I did the chrome tank dash,saddle bags and the breather cover. It's holding up great. Just takes patience to get it right. You have to do a minimum of 5 coats. I've power washed it and everything. Still looks perfect.
    Feb 2011
    Patience is the key. Rustolium makes a similar spray that I have had good success with. The first time I used it I puddled it, but wiped the excess with my finger and kept adding coats. Came out smooth.
    Those bags look great xBobbyx.
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    MMMII
    Looks great. What paint did you use. I stopped using plastic dip didn't seem to hold up the the Sun and you being from Vegas you get plenty of Sun and Heat.
    Henderson, NV
    Quote Originally Posted by ABQSpyder View Post
    MMMII
    Thanks! I used Valspar Black High Gloss Spray Paint which can be picked up at Lowes. Item #113549.
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    Good job, looks much better!
    VHT Epoxy has worked well for me.
    May 2014
    Texas
    Thanks. The bags turned out better than I expected. The spray paint does look good. It's little things like that,that I think BRP should think about. They should come black already. Just my opinion.
