Page 2 of 16 FirstFirst 12345612 ... LastLast
Results 26 to 50 of 378
  1. #26
    Dec 2012
    Murphy, NC
    Steve can you give more information in layman's terms what reworking the vehicle's fuel system means?
    2020 F3 Ltd
    Spyderpops Bumpskid
  2. #27
    Aug 2010
    Riverside, California
    I could see that this scoop might even help the earlier years that have heat issues as well. A fix that looks good, Well Done!
  3. #28
    Bryant, Arkansas
    Thanks, BRP, I know many people have been waiting for this.
    Cruzr Joe
  4. #29
    May 2013
    Stanton, ca
    Quote Originally Posted by stevedfive View Post
    +100 Steve!
    Hoping BRP will eventually make these as orderable parts. Problem might be matching the paint of older models.
    Bob
  5. #30
    Jun 2013
    queens ny
    i basically did the same thing and sorry to say i don't really think it helped. sorry to be the downer on this but i say it like i see it. the heat coming out on my feet was still too much for me to handle so i sold the bike. now let me say that the heat doesn't bother the new owner as much as it did me. i do hope the multiple updates Steve talks about helps also.
  6. #31
    Jul 2013
    Vestaburg Michigan
    Question
    This appears to be where the adjustable air vents are mounted! Is BRP going to refund the money I paid for them? It a pears that I can no longer use them.
    I am glad they came up with a solution, so I was wondering what I will do with these vents I invested in?
    Please correct me if I am wrong.
  7. #32
    May 2013
    Stanton, ca
    Quote Originally Posted by cuznjohn View Post
    I am going to go out on a limb here about the scoops as I have had my Spyder apart many times and looked at this area for a DIY.
    The stock openings these vents feed is paneled off inside to the full internal engine area (they seem to be there to let heat from the radiator go up and out when your not moving).
    My bet is just adding the scoops is not all they are doing. I think there is also going to be panel mods inside to direct the air from these scoops the back of the engine area.
    Steve, care to elaborate? We are curious
    Bob
  8. #33
    May 2013
    Stanton, ca
    Quote Originally Posted by Larry rt View Post
    Yes it looks like you will be losing the adjustable vents! Time for a aftermarket setup I think
    Or figure out a way to mount the ones you have. Probably would not be hard.
    Bob
  9. #34
    Jun 2013
    Québec, Canada
    Hi Larry rt,
    If you're referring to the BRP Fixed upper wind deflector or BRP Adjustable side wind deflector, you will be credited for the current retail price of these items after they are removed and the recall has been performed on your Spyder. Your dealer will manage reimbursements for these items for use as credit for parts, accessories or maintenance services.
  10. #35
    Post them in hers... Somebody will find a good use for them!
  11. #36
    Jun 2013
    queens ny
    Quote Originally Posted by finless View Post
    Bob
    like i said, i hope it does work for the others having it done. i also did the bottom air vents but i still had hot air from the radiator blowing on my feet. i would of bet my bottom dollar that BRP would of tried to put a reversing fan motor on the radiator like the 14's, because that really worked wonders .
  12. #37
    May 2013
    Stanton, ca
    Quote Originally Posted by BRPcare View Post
    Hi Larry rt,
    That's pretty darn cool right there BRP!
    Bob
  13. #38
    May 2013
    Stanton, ca
    Someone on Facebook said they were a "tester" for this fix and in fact that they added the reverse fan.
    Now realize one person saying this doesn't mean anything (it's the internet ) and even as a tester, that does not mean this was the final setup chosen by BRP.
    Bob
  14. #39
    Jun 2013
    queens ny
    here is the bottom vent i put on the bike
  15. #40
    Feb 2015
    California
    Hey Gang,
    Before we start down the rabbit hole of bad things, let's remember that Steve posted that the fix included, but not limited to reworking fuel components and body panels. So I am going to assume they maybe including the reverse fan that is discussed along with a few other components here and there. They did say this was a pretty big fix. So Steve can you elaborate more on exactly all of the components for this recall and break it all down for us?
    2015 RT , Black
  16. #41
    May 2013
    Stanton, ca
    Would be "SWEET" if BRP posted the PDF of the instructions that come with the parts kit!
    Also the BOSS web bulletin.
    Please?
    Bob
  17. #42
    Mar 2014
    Troy Tn.
    Hi Larry rt,
    Thank you Steve for this , are there going to be a new style that will get some air to pilot & passenger , or means to make the adjustable attach to panels, in Tn.these are very importent .
  18. #43
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Hi barryj,
    Required parts for the campaign are currently available and will be shipped to dealers upon request. Get in touch with your dealer to set an appointment.
    Are the scoops part of the new panel or just an add on to the existing panel? Also will these scoops come painted to match existing color? Would be nice if panel was all one piece rather than an add on.
    Ride safe!
    2022 Sea-T0-Sky
  19. #44
    Jun 2013
    Have the call in to my dealer, and am looking forward to the work being completed . . . I have lots of trips on the calendar for this season.
    Thanks for sharing this, Steve . . .
  20. #45
    Jul 2013
    Vestaburg Michigan
    Thumbs up
    Steve, thanks for you quick reply! !
  21. #46
    Jun 2013
    Québec, Canada
    Hi finless,
    While for obvious reasons we can't post that publicly, dealers will obviously share with customers specifically what is being done when the recall update is performed on their vehicle.
  22. #47
    May 2013
    Stanton, ca
    Hi finless,
    Thanks Steve! But not sure what the obvious reasons are?
    It will get out at some point, it always does
    I can wait... I am just a techno nerd that likes to know things
    Thanks for your response!
    Bob
  23. #48
    Houston
    Bob
    Same here. The full instructions will be in the repair kits. A copy will get posted here soon enough. I will if we are the first to see them. Appointment scheduled for next week, parts are due in by June 2.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  24. #49
    Mar 2014
    Troy Tn.
    So will the adjustable vents be remounted someway ? In Tn. way to hot without, and do not care for otherones that are in the market.
  25. #50
    May 2015
    WA. USA
    Default No Info from dealer
    Just spoke to my dealer. Nothing in BOSSweb that came up for my VIN. 2013 RT-S. Hmmm
