Results 1 to 13 of 13
Thread: limited budget
    Active Member ingramsail's Avatar
    Aug 2012
    Oklahoma City, Okla.
    Default limited budget
    Limited budget witch wound you install at Spyderfest a sway bar ,cat bypass or baker air wings and why?
    Nov 2012
    North Las Vegas, NV
    Swaybar and an alignment. Handling is important.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2011
    GREENVILLE, SC
    Default DIY
    DIY and you can have them all.....
    jmho
    dan p
    SPYD3R F3-S
    Oct 2013
    rome new york
    AGREE!!!!!
    Nov 2013
    Oro Valley Arizona
    If you have a limited budget, you should buy a Honda or Suzuki. These Spiders are expensive and the "Farkles" are even more. If you had to make the choice a Ron's sway bar is a no brainer.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Sway bar is my vote. An alignment while you are there is another option hard to pass on.
    May 2012
    sussex, nj and tug hill, ny (west turin)
    sway bar!!!!
    Default There you have it..
    most bang for your buck..but as SPYD3R stated you can do these installs yourself or with friends and get them all or at least more than one. but if you still have to choose..BajaRon Swaybar and hiem joints...
    Aug 2009
    Ohio
    I can not disagree that handling isn't important but for me on '13 RT-L heat was the issues, I opt for the cat-bypass if you to are having heat issues.
    Aug 2012
    This was just a question, I agree the sway bar by Ron is one best and maybe first thing we should do. This is our third spyder 2010 RSS,2012RTS,and the first two have Ron sway bar and now a 2014 RTS SE6, we will be having the sway bar installed at Spyderfest.
    western Colorado
    Quote Originally Posted by ingramsail View Post
    I'm going to say Air wings just to be different! you did not mention anything about LED's? Would consider those before sway bar or cat bypass.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Sway Bar
    AJ
    2014 RT/S , Black
    Jan 2015
    San Antonio, Texas
    Swaybar and links
