Results 1 to 23 of 23
    Active Member rtlister's Avatar
    Feb 2015
    Anderson, SC
    Default Drive belt vibration above 65 mph on 2014 RT
    My 2014 Spyder RT Limited only has 4000 miles. It runs flawlessly until I get on the Interstate above 65 mph and there is an intermittent vibration. I was shocked the first time it happened. I read on Spyderlovers forum and figured out that it has to do with the drivebelt vibration and talked with the service dept at the dealership my Spyder came from. Unfortunately the dealership is 600 miles away. I'm just wondering if the warranty covers this. I'm led to believe from the forum that the belt tension or alignment is off. Any suggestions ...and would this be corrected by warranty?
    USA, Alabama, Leeds
    Sep 2014
    3rd ROCK FROM THE SUN !
    I had the same sort of vibration on my 2014 RT limited at the speeds you mentioned... brought it to the dealer to check the belt tension... they said it was "spot on".. so I installed a Belt Tensioner... the vibration on my spyder is G-O-N-E
    osml
    Northern Kalifornia
    Default Me too,
    one would think BRP could have cured this issue by simply selling their machines with a tightener installed. Their price $30, our price to fix their oversight $185. Comfortable ride, better reputation, priceless.
    May 2013
    Apex, N.C.
    I had a slight vibration at between 75 and 79 mph. Once I took mine in for the 3k mile service, they checked everything. I assume that they made an adjustment in the belt, but cause now the vibration is gone.
    Quote Originally Posted by Orange Spyder Man View Post
    osml
    Question: Was any drilling required for installation on your bike?
    (I've got the same year and model here...)
    Sep 2014
    USA
    No drilling required
    Thanks!
    Feb 2015
    Anderson, SC
    Thanks for the advise gang. I really appreciate it. But I'm still wondering if warranty will make an adjustment on the belt? Has anyone had experience with your warranty covering the belt tension? Because if I'm going to have to pay the dealership to adjust the belt (on a practically brand new bike) I might as well go ahead and buy the belt tensioner :-{ Thanks again for the advise.
    Invalid Emails
    Feb 2015
    Wichita, KS
    Default Me too
    I'm just three weeks into a 2014 Spyder RT Limited. I noticed the intermittent vibrations on a 50 mile trip today -- on good smooth highway. The sensation was kind of like running over really old, worn-out rumble strips on the highway before stop signs. I kept looking down at the pavement to see if I could see any roughness but couldn't find any. I bought it as a "demo" bike with only 300 miles on it. Guess I'll drop by my dealership and see what they have to say. Like others have said, it'd be frustrating to have to shell out $185 for a solution.
    Feb 2015
    Anderson, SC
    You are describing exactly what I've experienced (as I mentioned at the first of this thread). It's the same thing. And mine was doing it at 2000 miles as well so I feel sure it was doing this from the factory. My problem is that I got my Spyder from a dealership that is 600 miles away. If I made the 1200 mile round trip back to the dealership, I fell sure that dealership would take a look and maybe make an adjustment if they felt it necessary. But over the phone I get the impression that this is not going to be covered by warranty. And if that is true, it would be very disappointing since I feel sure it was doing this out of the factory. So, if you wouldn't mind, please let me know how your dealer responds (warranty?). Thanks
    Feb 2015
    Anderson, SC
    I'm also wondering if BRP is aware of this ...seems like this is not uncommon!
    They are aware of the belt harmonics issue...
    Jun 2010
    Las Vegas
    My 2014 RT did it at 70 mph but now with 36,000 miles on it I don't think it does it anymore. Or I no longer care.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default VIBRATION
    I've got a 2013 RTS-SE5 which also has some vibration around 70 mph, I'm thinking of putting a belt tensioner on this spring and hope that fixes the problem..
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Sep 2014
    East Texas
    Default Step 1 : Read the directions Step 2: Follow them Step 3: Ride happily
    You can choose to be a victim of " belt issues " or you can choose to purchase a Gates sonic tension meter and a manual. Read and follow the directions and you will amazed at the results. I chose to do this and now whenever I feel belt vibration, I pull in my garage and check the belt. Don't be a victim of dealer BS, take control. It's very empowering. You don't need anything aftermarket to fix this. The only thing I would change in the instructions would be to increase belt tension 1/8 of a turn at a time, instead of the recommended 1/4 of a turn at a time as this is way too much change between checks. Take a "Sharpie" and mark where the tensioner is before you start adjusting.
    Oct 2014
    The Dalles, Oregon
    Sounds good to me. This vibration thing sounds like those of us that do not have it are lucky but it could happen sometime. Could it be a difference in belts or something similar?
    Sep 2014
    Bob... no drilling required... you do have to remove some body panels...
    osm
    Feb 2015
    Anderson, SC
    Quote Originally Posted by Ben Burped View Post
    Thanks Ben for the tip on the Gates Sonic Tension Meter. Any chance you would have handy a link? Also curious if you had the same vibration issue (above 65 mph)? And what model Spyder do you have?
    Nov 2014
    Temecula, California
    Took my F3-S into the dealership for the issue of vibration, 65-73 mph.... Brp told dealer to double check the belt tension and spacing, both were with in spec. BRP told dealer any deviation from spec. will cause excessive wear on other parts.
    I am not mechanically inclined but wouldn't adding a tensioner or adjusting the belt more cause it to be out of spec. there by causing more issues later
    if BRP facts are to be trusted???? I would like it to disappear, too but wonder if the added tension is hurting something else?
    2015 F3S , Black & White
    Feb 2015
    Wisconsin
    I wonder if other bikes with belt drives have these issues?
    Does anyone understand the benefits of belt drives vs chain drive. Other than the obvious fact you don't have to grease a belt.
    Oct 2010
    Somewhere out there...
    Realize that the Spyder has one of the longest belts on a vehicle in the market. There will be some vibration and they have been aware of it since the beginning. You can either live with it or get a 3rd party tensioner.
