Blur ridge windshield on my F3
Today I installed the blue ridge windshield on my F3,install was easy,it looks great and works perfectly .went on an hour ride and what a difference.
i also moved the foot pegs from 3 to 4 and really like the change,my legs are pushed forward a little more but just the right distance.
tomorrow I'm adding kury ISO clamshell grips.i heard an F3 with the stock muffler and the cat removed,OMG,nice sound,I ordered my bypass and will be installed next Friday.
i love this machine,it's just awesome.
Could you get the measurement of the windshield for me length / height and width thanks. I'm sure I won't be disappointed with it.
Genet, I have to tell you the stock exhaust with the bypass is the best combo. I was going to get another pipe, but this works so well and the sound is the best. You will notice a total different sound from idle when you take off and put a load on the pipe...love it.
Another Day To Be My Kid's Dad [emoji379]
Thanks,I can't wait to get it done.
i was going to get the tailgunner,but I think I will just do this.
the guy that owned the one I heard today also said the performance is even better,I can't imagine it could get better.
Right! I just listened to the Tailgunner pipe and honestly don't care for that sound, just not for me.
If you do the bypass does the tuner need to be changed so it doesn't run too lean? Thanks in advance for your help.
Great..!!
You've been busy and you have plans..thats great. Pictures and audio when your done. Just saw Lamonts video of the F3 with the gunslinger exhaust (too loud)..congrats on your mods...
Thanks for Your Post
I am thinking with your foot controls at #4 position you must be a tad bit shorter than I am. I'm six feet tall and will need the #5 kit for sure. The Blue Ridge windshield will no doubt be my windshield too although I wonder whether or not I'll be too tall for it. As for the exhaust, I'll leave it alone for a while so I can afford other things like a passenger backrest, auxiliary lights and a set of saddlebags.
Bypass info?
And where is this bypass available? I must have missed that info.
Thanks!
Call Pitbull and ask for Whit. 417-863-1418.
SpyderLovers Founder
I think I have two left in stock and 10 more on order.
http://www.shopspyderlovers.com/prim...ent-pipe-1330/
Thank you for all your input. I am looking into the Blue Ridge windshield also so would you please let me know how tall you are and do you look over it or through it.
I have been ryding around with my Blue Ridge windshield and I think it does a fairly good job at redirecting the wind around me. Still some onto my helmet but I'm sure my Shoei modular helmet is mostly to blame for the slight "buffeting". I am 5' 8" and I am looking over the windshield. Aesthetically, it looks very good on the F3 and follows the lines well.
Robert
2022 Spyder RT SEA-TO-SKY Mystery Blue... (bought new May 2023, a work in progress...)
2015 Can-Am Red F3-S, SE6
CalSci shield, Elka stage 5 rear shock, stage 4 front shocks, Akrapovic silencer, BajaRon Bar, Roadster Renovations vibration dampener, Tricled LED headlights and auxiliary lights, driver floorboard, driver and passenger backrests, Tricled Safety Led package, Shad BRP/SH36 side cases, Baker built luggage rack, Tricled Rear run/brake/turn signal led, Tricled LED piezo brake bullet strobe, JDM Astar LED bulbs for rear and front lights, Airhawk seat pad, USB power outlet
Robert
Thank you for the info. I'm also 5' 8" so it should work for me also. Can it be removed easy so I can go back and forth with the spoiler one. The only time I use a windshield is when I travel or winter months.
I couldn't say for sure as I had the dealer install it but I would imagine it is relatively easy. Someone who installed it themself can chime in on that for you. You will definitely like the windshield.
Have fun!
I installed mine it's easy 4 screws.
No. Modern ECUs can cope with fairly large swings in exhaust flow. My RS-S had a Hindle fitted and didn't run so lean it would
cause problems.
I'm 5'9" and for the most part look over it, except maybe 10 feet right in front is through it. It is really perfect for me.
