Results 1 to 10 of 10
    buffalo ny
    Default 2013 st sway bar
    Anyone ever change there factory sway bar. Just seems that the front end dips down to easy. Any recommendations would be great. Thanks
    Default Oh yeah..!!
    hundreds... one of the best mods you can do and if you search it here you will get tons of reviews on the changes and effects...all good..!!
    Jun 2010
    Las Vegas
    The sway bar is probably the single best mod you can do on your Spyder.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Henderson, NV
    No truer words have been spoken on this forum.
    Apr 2012
    Northglenn Colorado
    My Friend has a 2013 ST and I have 2012 RS SE5. We put the swaybars on the same day in his garage. Putting them on the ST is a big job, mainly because you have to get the front end of the ST so high off the ground. If you have the right equipment it would be better. We used a jack and cinder blocks and plywood, alternating each side until we got it high enough. It was pretty comical but we got the job done. He noticed a big difference on the ST after the install. The RS was pretty simple compared to that but we did not notice a drastic change for the RS.
    Quote Originally Posted by Tazzel View Post
    It is a matter of degrees. The 2013/14 ST/RS/RSS models REALLY need a lot of Sway Bar help. So you will see a great deal of improvement there.
    The 2008-2012 RS/RSS models need sway bar help too, but not as much. The difference is still significant, but not as dramatic as for other models that needed more help to start with.
    The real eye opener is when you get accustomed to riding the improved sway bar and then ride a stock Spyder. That will get your attention!
    Have Fun This Summer!
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default F3-S
    Ron just wondering have you heard from Lamont or anyone else if they feel the need for a Baja Ron bar? Are you going to make one? Just wondering.
    14 RT-S , Stock Large brake pedal White Pearl
    Quote Originally Posted by NM Wrench View Post
    I have not looked into the F3 yet. If a bar will help it, I will make one.
    Invalid Emails
    Jun 2013
    Port Angeles Wa
    Quote Originally Posted by spideybuffal0 View Post
    Make sure you buy the Baja Ron sway bar and not the one that BRP offers. You will notice a big difference in the corners.
    Ron is a spyder lovers site sponsor. You can also buy his Sway bar through Value Accessories also a site sponsor just go to the home page scroll down and click on one of the Ads also don't forget to get the upgraded aluminum links.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    We put one on my wife's old 09 RS as well as her 13 STL. She said that she sees a big difference. It is not a hard job to do, you just have to get the font end high enough off the ground. If you are stuck and want to do the 5 hour drive to my place we can put it on together. I have all the tools needed. Although, your dealer should be able to put it on as well. If you don't get it done until the fall, make a trip to Spyderquest in September and you can get it done there.
