Results 1 to 12 of 12
Thread: 20W LED Spots
    Nov 2014
    TriCities, WA
    Default 20W LED Spots
    I don't know how you guys get such good pictures of your LED installs, but I post what I took. These are 20W only about 1.5" in diameter.
    Mounted them on the top of the lower arm. Hot glued the wires under the bottom side to the ends. I have them wired into the headlight circuit, but added a switch in case they weren't aligned quite right and were blinding people. Yes, I added an air horn and the longer horn, I stuck in the same place, but its tucked behind the frunk.
    Nov 2014
    TriCities, WA
    Couple of more pixs. Pix 1 is without LEDS, Pix 2 is with at about 30'
    Active Member danotech's Avatar
    KC
    Where did you get the lights and how much?
    Sent from my Nexus 7 using Tapatalk
    Nov 2014
    TriCities, WA
    Quote Originally Posted by danotech View Post
    http://www.ebay.com/sch/i.html?_from...e+LED&_sacat=0
    I paid $13 free shipping, they come from China, so about a month to get them. I used this guy:
    Seller:
    ylhkeepfeeling (2313 )
    Nov 2014
    TriCities, WA
    Liked the first two, so bought 2 more. This is daylight about 20-25 feet away. At night blinding. I added a switch so I could kill them if I get flashed. I think that I will wigwag the upper 2, waiting for the wigwag thing.
    Default WORD OF CAUTION
    Bill, I'm an X- LEO, and I would be very careful about doing the " WIG-WAG " thing......That is a Police ONLY thing in most jurisdictions .......If they BLINK together I think your OK tho.........I would check with the Locals ..........................Mike
    Nov 2014
    TriCities, WA
    Thanks for reminding me that things change. Apparently, you use to be able to have a wigwag, but in WA no flashing white lites projecting forward. Actually, its a bit contradictory as to whether or not you can have more than 2 extra forward lights at all. One RCW says no, and another it says yes. You do need a switch so you can turn them off if need be. Also no blue light anywhere on the car flashing or not, and no red light facing forward, flashing or not. Unless of course you are an authorized emergency vehicle.
    So we learn everyday if we are lucky.
    Active Member markyodo's Avatar
    Columbus, OH USA
    Question
    Would you mind posting some closeup photos of the mounting locations (with the lights off)? I love your install but I am having a hard time picturing how/where you mounted the lights.
    Thanks...
    Our Scenic Life - Spyder Videos
    https://www.youtube.com/channel/OurScenicLife
    Ask me about my Spyder.
    2014 Black Can-Am Spyder RT
    Nov 2014
    TriCities, WA
    Quote Originally Posted by markyodo View Post
    Thanks...
    Being ADD I'm not much on perfection. Here are more pixs I hope this helps. I would wire in a switch, so if they are too bright or misaligned you can kill them.
    Mar 2013
    South East Wisconsin
    Default What is the output of
    lumens if you don't mind me asking??
    Invalid Emails
    Ormond Beach FL
    Cool Wow
    You can definitely say you are visible
    Nov 2014
    TriCities, WA
    Quote Originally Posted by wis2013rtltd View Post
    850 each (20W)
