Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 85
  1. #26
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  2. #27
    Jul 2011
    Mitchell, Ontario, Canada
    Default Unable to complete order
    I tried to order one. After I entered my shipping address, there was a message "Unable to calculate shipping Fee"
    Do you not ship to Canada?
  3. #28
    USA, PA York
    Default Welcome
    I placed an order with him 2 days ago and my item came today. Great service, thank you.
  4. #29
    RT-S PE#0256 SyderLovers Sponsor
    Jan 2008
    Prescott, AZ
    I do ship to Canada. Email me what you want to order (for shipping weight) and your address so I can get a shipping quote and we will take it from there.
    Matt@lidlox.com
  5. #30
    Jul 2011
    Quote Originally Posted by Mad Matt View Post
    Matt@lidlox.com
    Email sent
  6. #31
    Sep 2014
    Los Angeles
    Matt...picked up some stainless steel 8/32 2" to try and reach threads in the bars. Also some washers to fill in the larger hole to it doesn't pull through your lock.
  7. #32
    Houston
    I ordered a pair of the Lidlox for our Kuryakyn ISO grips. They arrived in 2 days and are very nice quality. Just finished the 5 minute install and they fit perfectly. One on each of our bikes.
    Welcome new Spyderlovers Sponsor and thanks for a great quality product for our bikes!
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  8. #33
    Sep 2012
    Junction City, KS, USA
    Will you be selling at SpyderFest?
  9. #34
    Jan 2008
    Prescott, AZ
    Quote Originally Posted by GunDoctor View Post
    It looks the same as all the rest installed, but I need a stronger screw than a drawer pull one. I will also need to put a washer to take up the space because the hole in the kit accommodates the larger hex bolt you provided. Likely try a hardware store this weekend and see if I can't find a proper bolt. When I saw that the factory screw in the grip was slotted for a Phillips head, which was loose to start out and replaced it, it doesn't tighten. Don't know if it was striped when it was assembled or not, so I put a very small amount of locktite for now.
    I think my 7/8 universal kit with the rubber plugs will work on those Spyders. Its just been years since I worked on those so I don't remember the end cap exactly. If you can take the end cap off and see inside the handlebar ends, then the rubber plug setup will work.
    Watch this video:
    Send me a pic of your end cap on and removed and I should be able to get you all set.
    Matt
  10. #35
    Sep 2014
    Los Angeles
    Sorry Matt I just saw this after I put on all the new parts I got today at Lowe's. The 2" screw works perfect and it tightened up and I also used Blue Permatex Thread locker.
  11. #36
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Thanks All! Don't Forget to use your SpyderLovers coupon code.
    15% Off for all SpyderLovers for the first 50 customers.
    enter code spyderlovers in the webstore.
    Matt
    Matt,
    I received my order today. Very pleased with the fast shipping and the quality of the product. Best of luck to you.
    Take Care,
    Louie
    2015 RTL , Red
  12. #37
    Aug 2013
    Fermont, Quebec, Canada
    Arrow
    I don't have any chrome ones at the moment, but I have had a few requests so I will run a batch through chrome. That usually takes 4-6 weeks b4 I have them back.
    Matt
    Thank you Matt...
    Just tell me when you will have a set in hand and i'lll order one.
  13. #38
    Active Member randyandsandy74's Avatar
    May 2014
    Thank you Matt, for the discount. I did forget the code, again thanks
  14. #39
    Jan 2008
    Prescott, AZ
    Thanks Spyderlovers for your great support ! Once again, don't forget to enter spyderlovers in the coupon at checkout for forum members 15% discount. There are only about 20 coupons left out of the 50 so get em while they last! Also, I know a lot of customers who have other bikes come back for Lidlox for their other bikes once they have them on their primary bike. So take advantage of the coupon if you want a set for your Victory, Harley, BMW or whatever. Just email me if you have a question about fitment.
    Matt
  15. #40
    USA, Alabama, Leeds
    Default Thanks Matt
    I got my LidLocks in 2 days.... installed in about 15 minutes and they are the BOMB.... works like a champ... easy, secure, simple.... could not ask for a better product or customer service.
    Well Done Sir!
  16. #41
    SE Pennsylvania
    Default Half cover and helmet locks
    Quote Originally Posted by ursamajor35126 View Post
    Well Done Sir!
    My question is: Will we be able to use a half cover on our Spyder while using these LidLocks? Looks like with the locks the helmets may spread out the cover too far on each side for a cover to fit correctly. Anyone know for sure? We would love to install these, but want to make sure everything works together before spending the cash, although it's only $79.
  17. #42
    Jan 2008
    Prescott, AZ
    Quote Originally Posted by LEEB View Post
    Give them a try. I have a 100% money back guarantee. If they don't work for you for any reason or you are not totally happy with them, just send em back and I will give you a full refund of your purchase plus shipping.
    Matt
  18. #43
    May 2013
    Hackensack, MN.
    Default Thanks Matt
    Got my locks today. put them on this afternoon.Work great !
  19. #44
    Oct 2014
    cohoes ny
    Do you have one for an 08 rs?
    does the left handgrip install the same way for the 2nd helmet?
  20. #45
    Jun 2014
    Schenevus NY
    Order placed.
    Little by little building up my farkles!
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
  21. #46
    Jan 2008
    Prescott, AZ
    Quote Originally Posted by Kwalsh View Post
    Yes and Yes. The 7/8 Universal Kit works on the old RS models with the plastic end caps.
    http://lidlox.com/t/universal
    Matt
  22. #47
    Apr 2012
    Waynesboro, PA
    Default Second pair
    Just ordered my second pair for my 2012 RTL. It took longer to remove from blisterpak then to install on my 2014 RT. Great product
  23. #48
    Houston
    Great timing! Needed something like this a couple of weeks ago. Just ordered a double set for our Spyders!
  24. #49
    Apr 2012
    Waynesboro, PA
    I know it fits with the can am full cover
  25. #50
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    I ordered my set early on from Matt. But it's been so dang cold in my unheated garage that I just don't feel like installing them yet. But I know I'm gonna love them when I do.
    I got them in black, but since I have both black and chrome end caps , I just may wait a little while to remove them from that shrink wrap card. I think I might like the chrome ones even better when Matt gets some in, and maybe he'll let me exchange them.
    I agree that Matt, and these helmet locks, are .
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
