2014s Go To Orange Long Life Coolant
Not sure if this has been mentioned, but BRP is switching over to Long Life Coolant on most all of their 2014 product lines, including Spyders and Ski-Doos. it is orange in color, and BRP says it is doing so for the longer service life (since so few of people replace coolant in their aluminum block engines these days) and for the increased corrosion protection. They claim it has better boiling behavior (erosion in the water jacket) as well. They also are telling us we should not be mixing the orange coolant with green or any other type of coolant, in fear of it gelling. We just saw it in some new ski-doos and noticed a service bulletin stating the same was coming for 2014 Spyders. Their part # for the new stuff is 219 702 685, but I am sure we can figure out what else will be compatible. Thought it was a good heads-up for all of us here.
2021 RT Limited - Deep Marsala Red 4,200 miles
2013 ST-S SE-5 - Circuit Yellow 56,000 miles
2015 F3-S SM-6 - Can-Am Red Solid Gloss 2,000 miles - SOLD
2008 GS SM-5 Premier Edition #659 - Full Moon 34,000 miles - SOLD
2008 GS SM-5 Premier Edition #006 - Full Moon 34,800 miles - SOLD
Through the years, I've been consistent in having my coolant in my cars flushed and all the hoses replaced, every two years . . . since I started that, I've never been stranded by the side of the road with steam coming out from under the hood. I had planned to do the same with my Spyder . . . especially because of the heat under the Tupperware . . . that can't be doing those hoses any good!
So I suppose flushing out the existing coolant and replacing it to Orange Long Life Coolant would be the recommended thing to do.
coolent
my bike is still in the shop for the heat recall waiting for the canister, the service manager was telling me they are using a new anti freeze but not in the spyder, it has a higher boiling point
2014 Spyder is included
BRP is switching to the orange long life coolant on all of their vehicle platforms, only a few select models are excluded. What your service manager told you is incorrect. 2014 Spyders will have orange long life coolant. If he does not believe you tell him to go read roadster service bulletin #2014-1.
As for switching over an earlier model year unit, this would be the ideal course of action once your unit reaches the specified replacement interval. You could do it earlier if you want the added benefit of higher boiling temp and increased corrosion protection, but you could wait until the specified replacement interval. This bulletin also details the flushing procedure to switch from green to orange coolant. Pretty much a matter of draining the green, filling with distilled water, bring to operating temperature, let engine cool, drain water, refill and bleed with new orange coolant.
The bulletin also states that some of the 2014 literature might refer to the green coolant, even owners manuals and shop manuals, as some of this material was printed before the change was validated. Always verify which color of coolant is in a vehicle before adding more.
GM has had all sorts of issues with that orange stuff. After replacing many gaskets on various GM cars and trucks because of that orange stuff I promptly remove it from all my engines and replace with green. If I have to change it more often then so be it, cheaper than tearing down to replace gasket throughout the engine!
Pardon me for resurrecting an old thread but if you've seen my other posts about a leak, I've determined that the leak is orange. This thread seems to confirm that it is coolant.
Now the problem is I've been topping it off with 50-50 *green* pre-mix. I don't remember seeing anything in the owners manual about only using orange long-life coolant; did I miss something? Or did I just screw myself even more?
Trb--
Mixing green ethylene glycol based coolant with orange organic acid long life coolant is a big no no. You made a mess. The system needs to be drained, flushed and cleaned. Then refilled with the proper coolant.
The mix can gel and it can eat aluminum parts. Bad news.
Was Briefed
When I picked up my 2014 RT-L in September, the service manager mentioned the orange coolant was the standard for my Spyder. He warned us not to mix with the traditional green. Was easy for me.... Orange (Cognac) Spyder uses Orange Coolant.
This is copied from the 2014 RT Owners Manual:
The cooling system must be filled with
distilled water and antifreeze solution
(50% distilled water, 50% antifreeze).
For best performance, use the LONG
LIFE ANTIFREEZE (P/N 219 702 685).
and this from the 2013 RT Owners Manual:
For best performance, use the BRP
PREMIXED COOLANT (P/N 219 700
362).
So they did change the part number
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Big difference between "For best performance" and "You must use"
Sent from my Nexus 4 using Tapatalk
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
I agree, if it is wrong to mix them they should probably tell you that. Only use xxx or equivalent would say a lot more than "for best performance"
2010 RT- 622
Was reading a thread on BITOG yesterday saying that some
LONG LIFE anti-freeze will cause gelling and really screw up the
system when MIXED with certain non-long life. The point was
made that the system should be drained, then filled with filtered water and run for awhile, drained again, then add the long life stuff.
Personally, I'm gonna leave what I have in and change it for same stuff in a couple of years UNLESS the draining process is
a major headache. If so, I may then go with the long life.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I just took another look at the bottle. Says it's compatible with any other antifreeze, any color. Between that and the wording in the owner's manual, I think I'm good, at least short term.
Trb--
Trb--
Did it by chance give the chemical make up?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Share how that works for you
Seems that I remember that the threads tended to come out with the radiator drain plugs leaving people with the unplanned expense of replacing the radiator when the coolant was changed, so share with the spyder loving world how that works for you.
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
The long life coolant never should be mixed with the traditional coolant it is a big no no!
Also I have a lot of dealings with the Orange Dexcool from GM with working at a GM dealer that stuff Is horrible on a coolant system when it starts to break down and it doesn't last the mileage that they say it does . If your looking for better cooling agents look into something like (water wetter) it will work much better but it to does require maintance.
Bill, Isn't water wetter an additive to existing coolant? What
are the maintenance requirements?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Guys, don't confuse "long life coolant" with "dexcool". Has anyone actually checked. You can't go by color anymore. They DO have an orange HOAT long life coolant that is not dexcool....
Knowing the spyder is Canadian I'd likely believe it's orange dyed G-05 coolant.
When Was Change Made
My RT-S was built 3/4/14 and to the best I can determine has green antifreeze. Vossr picked up his in Sept. and was told it's orange? For me it's a 3,000 mile service question later this month or next.
Water wetter can be added to coolant but it is most effective running it with just water , the only problem is it will not protect in freezing conditions and will need at least antifreeze added for winter storage or winter riding.
That is correct coolant has a dye added, Honda has blue GM and Chrysler use orange now and fords in the short past that I was working for them was yellow.
Fairly certain dexcool is a GM only isn't it??? Bill?
