Tire needed?
Here's a couple pics of my rear tire. I have just over 7000 miles on it and plan about another 1000 by the end of October. Do you think I should go ahead a beta new one?
JMHO but you need a new tire now rather than later. I would be worry riding in the rain and hydroplaning. That's just me better safe than sorry my tire looked like mine at just over 12,000 miles this spring and I got a new tire put on just before our week long tour.
Looks like you've had too much air in it.
Huh?
What tire? That is nothing but "wish tire". You WISH it was a tire. You are living dangerously on borrowed time. A blow out wouldn't be much fun on a Spyder..
Yep, I'd get it changed NOW.
Ummm...let's see...you need a new tire.
Yeah, that's the ticket.
You beta your life you need a new tire..
Dennis
Dennis
Okay, okay, you folks above are winning me over too.
Buy the tire Prairie Spyder and then you won't have to worry about it.
YES BUY A NEW ONE RIGHT NOW
Cruzr Joe
You can order/have rear tire mounted for $8 at local Discount Tire store.
Just need to remove rear wheel & brake disc for them to mount Kumho tire.
Add 16 oz Ride-On to rear tire.
Have a safe ryde to Lamonster BBQ.
Jim
I'll see if I can get one soon and maybe take it to Springfield with me and ask PitBull's to install it.
Thanks.
EDIT: Or have it installed here, if the local HD dealer will do it.
YIKES
YIKES.......! ! ! ! ! ! ! ! !
YOU NEED A NEW ONE FAST..............
SpyderLovers Sponsor
Buy a tire right now or invest in some good walking shoes. Your definitely going to need one or the other soon.
Too much Air
And don't run so much air in the new one! I'm running 22lb and keeping close measurements across the tread. With nearly 5K I still have lots of tread evenly all across.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Yep! Agree 100% with the majority....you need a tire like asap!
I would also suggest a few pounds less pressure in the replacement.
PS. In the UK I would be fined and penalised if the police caught me using
a tire that badly worn.
keep in mind the number 1 safety feature on any vehicle is the tire.
Let's not assume she's running too much pressure. Running proper air pressure can still cause wear like that.
I called the local HD service manager. He said they would do it but he wants to look at the Spyder to see what is involved, since he's not so familiar with them.
So my new question is: do they have to remove any tupperware to change a tire?
I'll take it by there this afternoon and see what he says.
Thanks to you all.
NO BUT
Thanks to you all.
......I see you have a 2014 RT........Tupperware can stay ...But the airbag needs to be addressed and someone will chime in here ......I hope ...Mike
Depends..!
on your weather and season. Here not having rain and normally hot sunny weather I rode mine a lot further. When I hit the wear bar I replaced it. Now thats me and here in socal. In your case IMO replace it prior to the time you slow down or weather changes.
Don't need to remove tupperwear but take your manual for them to see.....
Yup, that would get you 3 points on your licence here (12 for a ban) plus a cash fine!
Please get a tire, they must disconnect the leveler on the air ride and let the air out of the air bag. taking the bottom shock bolt out and let the swing arm drop this will mean the belt comes off without touching the adjusters. No tupperware needs to be removed.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
