Low Speed Wreck, Lots of Damage
First- no injuries....
This weekend we were about 200 miles away on a multi day ride. Lots of technical roads in the mountains. My wife was on her RTS with a passenger on the back, I was following on my Concours. We were making a left turn onto a highway on ramp, and her left front wheel lifted up. She corrected, but by then they hit gravel on the side of the road and slid into the guardrail at around 15mph. There is a LOT of damage. The right front wheel is a full 8" behind the left wheel when you look at them. The handlebars are at almost a full left lock with the wheels straight. The seat/rear of the bike is twisted to the right. Cosmetically, the headlight is smashed, the right fender is damaged and there are scrapes on the frunk lid.
After all the technical roads we had ridden it was bizzare that this happened. The only thing we can see is that the ramp was tilted from left to right- the left side of the road was higher than the right, and that, combined with the left turn, is what caused the wheel to lift.
We had to drive back out there yesterday with a trailer and bring it home. I'm hoping it's repairable- if it's just steering components and no frame damage.
Anyone had a similar mishap, and what was the outcome?
Is everybody okay??
Without seeing pictures; you probably do have frame damage.
I hope everyone is okay and safe! I'm sorry that you had this happened and I hope I don't ever have to come back and share a similar experience.
Can't help you with the specifics of your wreck, but it sounds like a weight distribution and speed issue. If the wheel lifts up the computer should have down-throttled.
Again, sorry this happened and hope everyone is okay... that's whats important!
I'm thankful there were no injuries. I hope the damage isn't too severe and she'll be back on the road again soon.
Mine was repaired; to the tune of $12,900...
That'd be fine with me...
Its likely total loss, or should be. The frame where those suspension arms mount is likely badly damaged. I would not want a bike that had sustained significant frame damage and been repaired. Anything CAN be repaired but should you?
Insurance does not pay what you paid for the bike, they pay what the bike is worth today to replace with like kind and quality. If the value went up in your case (not likely) they pay more than you did. ACV normally works in the insurance company favor, but not always. Been there and done that on a high dollar car wreck.
Glad no one was seriously injured. Can't tell by the pictures if there is frame damage. Going to take a very knowledgeable tech to do a thorough inspection.
We paid 16k for it earlier this year. KBB was over 17k yesterday. So we'd be covered, but replacing it would not be practical, because of the cost of a new one, or even finding a deal like this on a 2012.
It just stinks that such a low speed impact causes this much damage.
Glad there were no serious injuries . . . that is the most important outcome, here.
This is why I'm a bit concerned about the SST framework; they just don't take impacts all that well. They twist!
I have to go get a couple of pictures of the frame that came out from under mine... It shows how unsuported and weak these actually are.
I am very glad no one was hurt.
A wheel lift can be unnerving, but it is rarely reason to make much more than a minor correction. In almost every case, the wheel will come down with no harm, no foul. The perception of a wheel lift is much worse than the reality.
It may well be that the passenger was surprised by the off camber, felt like they were losing balance, grabbed a hand rail and hoisted themselves against the lean. The farther back and the higher the weight, the more affect it has on how much the Spyder leans.
Again, glad everyone is ok. But it doesn't hurt to mentally prepare for as many 'Surprises' as you can. Like, what will I do if an animal runs out in front of me. If you're mentally prepared it can greatly improve the outcome if it ever does happen.
Glad everyones OK
Sorry to hear about this accident! I am glad you are all OK...that's the main thing - it could have been much worse! Good luck with the repair!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Sad to read, but glad you are ok...
Always asking for pics...
These threads are my very least favorite to read, but we must. The lessons taught in these accident reports are what may keep some of us alive.
Yes, it's disturbing that these kind of things ever even happen, to good folks.
Let's hope you can get it fixed or replaced and have you back on the road very soon.
Wishing you only good luck, with much happier times ahead...
Chas
Top Heavy
Glad the ryder and passenger are OK!
Between the DW and I plus some stuff in the bags we are nearing the published weight load limit for our 2011 RT. When we were out the other day with a group of Spyders we occasionally lifted a wheel on the corners when keeping up with the other ryders, many of which were single ryders so they were much lighter than us and quicker around the corners. In addition, I like to goose it around the corners so that doesn't help! I just ignore it and let the nanny do it's thing if it wants to. We have not been anywhere near turning over, just feel the load come off the tire and possibly some traction loss but that traction loss could be imagined. When it happens I have to remind myself to just continue to hold or turn the handlebars in the direction I was going and just drive the Spyder! Reacting or over-reacting could be a really bad thing. The very last time it happened I caught myself (for a very brief moment) trying to correct by turning into oncoming traffic!!!
It is hard for me to get a tire off the ground with only me on it - I've tried - and I'm the heavier one of us. I need to remember when both of us are on we are top heavy and I should either take the corners a bit slower or just keep on - she says as long as we don't roll over it's all fun!
I dont think finding another used 2012 would be all that difficult. These spyders are not all that rare.
True- I have been searching cycletrader and they are out there, just have to travel to get them.
Gotta wait and see what the ins co says... might be a week til they have someone come out.
separation anxiety
After having our own accident just two weeks ago (Fall down Go boom boom thread) I can sympathize with you totally. It is a shock to have tipping issues with a trike that isn't supposed to. Our 2012 RT will be in the shop for quite a while getting a lot of new tupperware and we are missing her greatly.
Most importantly, all humans involved are OK! everything else is a learning experience, for you and all the rest of us who read and discuss your mishap.
Glad that everyone is okay and hoping you can be up running soon on a Spyder
2020 RTL SE6 Asphalt Grey
2014 RT SE6, Pearl White 57k (2014-2020)
2008 GS Premier 17k (2012-2014)
Dont forget that if there is not a comparable unit locally, the cost of transport to get the unit to you is part of the claim when figuring price for settlement. Not just KBB.
I can attest to off-camber roads being a real on the Spyder. Many a mountain curve has surprised me with a "weeeeee!!!" moment as a result.
That said, my observations:
1. It's not really necessary to do it while riding casually, but when riding technically, I *always* shift my weight to the inside. Even a single butt-cheek's worth of slip on the seat is almost always more than enough to keep the wheel planted.
2. The Spyder does have a *little* slip before the traction control kicks in. It won't kick the tail out as far as an actual drift, but there's enough there to help you around corners-- it just takes practice to figure out where the "sweet spot" of braking, cornering, and acceleration is.
3. An aftermarket anti-sway bar and upgraded shocks is always an improvement. The only downside to them, I feel, is that while it increases your performance margin, it simultaneously reduces your safety margin. Meaning, with a stock Spyder, the Nanny will kick in long before you hit the edge of the envelope. With a better bar and shocks, you'll be able to take corners at greater speeds before the Nanny kicks in-- which means that, when the Nanny finally *does* kick in, it's trying to save you in a more challenging situation with a lot less margin of error. Thus, when riding, YOU are even more responsible for your safety margin. Caveat emptor.
Anyway, my biggest piece of advice while riding is to always expect the unexpected (which, I guess, makes it all expected, no? ). Every blind corner will be off-camber, covered in gravel, infested with deer, and half-blocked by a logging truck driven by a dozing 95-year-old wondering why he can't get his Jitterbug to text. Do that, and you'll be safe!
Yeah, that's a total loss. You'll be in another spyder no problem. And like you've already found, the deals are definitely out there.
One extra benefit, if available to yours
My insurance company, offers a depreciation waver for $50.00 a year.
Well worth it, if ever needed...
Chas
Who is your insurance company?
Chas
That sounds like a good deal.
