Keyed power line
where/what is the easiest keyed power line to access in the frunk on a 2014 RTS?
Did yours come with the accessory cigarette lighter adapter in the frunk? If not, then there should a plug dangling (just kidding) behind the knock-out plug.
2020 RTL SE6
cool - thank you - didn't even think of that, but then..... thats why I asked a question here... lol
thanks again
turns out I did have my shop put in cig light adapter, but it is on a keyed circuit (or at least it is now as I moved the fuse from slot 7 to 6, or 8 to 7... whichever switches it from a live lead to a keyed lead)
I am assuming that I need to pull out the battery to get to the wiring leading behind that plug, or is there another way to get at those wires?
yes, I am lazy, and always looking for the easiest way to do things....
Power lead to the trunk opener solenoid.
14's don't have the button switch
Honestly, in the end frunk removal might be the "easiest" way. It really isn't that big of a deal. Not fun, mind you, just not overly difficult.
2020 RTL SE6
I was able to tap into the outlet for the keyed power source
But if it's an option then the wiring is there. The switch connects the ground side.
I don't recommend leaving the battery access cover like that. There is a lot of water sloshing around back there when washing or driving in the rain. It will make everything in your trunk wet.
I won't - I will cut a small area out so the cables can run thru and then use either rubber grommets or something else to help reseal the area
