So what I am seeing is a machine with no windshield, no bags, none of the options of the RT, none of the looks of the RS, and none of the well rounded abilities of the ST. The consensus is that it looks like there is an ACE1330 inside, a line of motors that has not exactly had a history of white knuckle performance. This motor was designed and tested in the snowmobile market and has historical data to draw from (much like the 990) without the added cost and liability of a completely new design. The new riding position (my favorite change) is more comfortable, but does not lend itself to stability in the saddle during more "spirited" rides.
That being said:
Is the new riding position worth the price of a base model RT, or a loaded ST? Not in my opinion.
What is adding one more model to the $20,000 price range really going to accomplish? Seems like everybody is fighting for a slice of
the same pie. And these slices are only going to get smaller with each model that gets added.
I did not guess in my earlier post I took the limited information I had in several photos and hypothesized. And if my fantasy is that the new spyder could be sold to the masses, and not only to a fraction of the available customer base, is that so wrong?
Just sayin'............
Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
The roads in NY are so bad that I am glad we bought a Ryker Rally
We haven't seen the entire package yet...
Just can't see a price coming in under $20k.There must be a lot of special cool-aid out there for those suggesting pricing under 10k
I don't think you should rule out that both power plants will be available - in two editions. Nor would I be surprised to see the 1330/6 in the STS LTD (only), while the 990 remains in the others.
This would allow BRP to have a large price spread, and with the "missing" tupperware and forward controls, keep the 990 cool enough to keep the new owners happy.
If the 2013 did not have so many issues, I would have expected a $17K 990 RT as well...
If the F3's production frame is similar to the proto pics, you are correct, that it is more expensive to build than the current frame. However, less plastic means lower costs too, add the no added farkles - like the base RS - and the base F3 could easily be in the $18K range - so I'll second the $18,995 number, and bet on a three model product range... How about that.....
...in the pink (Girls On Spyders)
I'm betting there are farkles...windshield....heated grips...bags...audio....etc.......the 2013 ST has had such a bad reputation....this just may be a replacement with no bad history....dump the problem...just a thought
![Quote](images/misc/quote_icon.png) Originally Posted by flamingobabe
Whether that is the grand plan or not, I suspect it will be the result
Pricing
![Quote](images/misc/quote_icon.png) Originally Posted by ViperWolf
Wonder where the F3 is going to fall into the 2015 price line spectrum?
I'm hoping its comfortable and has a slice of affordability to it.
Any thoughts, perspectives or wild a$$ guesses on pricing?
Impatiently waiting for more details...
I heard yesterday from reliable source that you can expect the mid $20's
So much for "reliable source ".... But my build did end up there. [emoji39]
