Results 1 to 21 of 21
Thread: Run Flat tires
    Jul 2010
    KILLEN, AL
    Default Run Flat tires
    Anyone put run flat tires on their Spyder? They have really stiff sidewalls and might help with the handling problems in addition to keeping you from being stranded! I'm probably putting one on the rear when mine wears out.
    Harper, Texas
    Personally, I would go with Ride-On in the tires, a laser alignment and Baja Ron's swaybar.
    Mar 2012
    NJ
    Good luck finding them in the proper sizes.
    U;ve never looked at the possibility...
    Are they available in the correct size?
    Does a run-flat tire reauire a different type of wheel?
    Mar 2012
    NJ
    It's an awesome idea for the spyder IMHO and I would for sure go run flats. However, while it doesn't require any special wheel, there are no current sizes that fit our application last I checked.
    Apr 2011
    GREENVILLE, SC
    Default SEARCHED
    I'VE SEARCHED AND SEARCHED, but can't find any in our required size....
    Dan P
    Easley, SC
    SPYD3R
    No special wheels...
    No sizes for us...
    Thanks for doing the heavy lifting on this one!
    Jul 2010
    KILLEN, AL
    They are available in the rear tire size. I didn't check on the front. The rear is where you need it the most anyway. They do not require a special rim. The first generation did.
    Deep South
    Default Run Flat Specifics
    Quote Originally Posted by mtdoragary View Post
    If you have the source and specifics of these tires available, would you post it please. Thank you.
    Which tire, and where??
    Jul 2010
    KILLEN, AL
    Still looking for what I found yesterday and failed to bookmark. But in the meantime, I found this: http://www.rodgard.com/runflats.htm
    Default How many flats have you had..!!
    does the added cost make it worth while. Cars and motorcycles tend to have more flats cause the front tires flip screws and nails up and the rear wheels run over them. Roadster rear wheel is not in line with the front wheels. I personally have not seen any flats with those we ryde with. I carry a plug kit and compressor because there is always that chance. I like the tires I use and the comfort and handling will change even more that a 4ply...
    Jun 2014
    ny
    absolutely do not mix run flat & regular tires on any vehicle & i would not recommend rft for a bike, they are way too
    stiff & you will feel every bump plus they have a much higher rate of getting a bubble & bending/cracking the wheels.
    The Missus has them on her MINI, and they caution against mixing them with conventional tires...
    I don't want to squelch my luck--check my signature. No problems so far.
    Nov 2013
    Oro Valley Arizona
    I would never put run flats on the Spyders or any other car that I own. The ride is horrendous and you feel and hear every ripple in the road. Two of the sport cars I have had came with them. Never again.
    If you think you have alignment problems now wait until you install run flats. Leave those for the homies and the customizers.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jul 2010
    KILLEN, AL
    Good points!
    Invalid Emails
    Ormond Beach FL
    Cool Ride quality
    As previously posted the quality of the ride has got to go down the tube with the sidewall stiffness t support the weight of a 3,000 # automobile versus a 900 # Spyder.. It should rank right up there as comparing fork lift solid rubber to a 8 ply 900x20 truck tire.
    If you want to do it try it but be sure to post your experiment results for sharing knowledge
    Jul 2010
    KILLEN, AL
    Quote Originally Posted by jaherbst View Post
    Jack
    Have them on my Corvette - over 100,000 miles on two sets with no problems and no complaints!
    Apr 2014
    Maryland
    Default Serious
    Quote Originally Posted by Gray Ghost View Post
    48 states ? I'm jealous
    Harper, Texas
    Quote Originally Posted by Souzan Druy View Post
    Thanks, it was a great trip, saw lots and saw a lot that we want to go back and spend more time at. Just about 16,000 miles in 71 days.
