Drive belt tension tool
I have found a couple of these and I am wondering which will be best. What does everyone else use?
Dayco 93866
Gates 91132
Goodyear 91107
Thanks!
I have the Gates Kriket 2 and seems to work pretty good.
Agree..!!
can't comment on the others...hope someonedoes come along with info...
Krikit to 300lbs.
Krikit 91132 - purchased mine at Amazon.com - works well for my 2014 RT
Dayco 93866
Gates 91132
Goodyear 91107
Thanks!
Here's a link for both Amazon and the write-up of the Gates (Krikit 91132)....In the fourth paragraph from the top of this article tells you the range (in lbs) of the unit and others to select from.
http://carbestreviews.com/Replacemen...rts-10464.html
Good luck!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
2020 RTL SE6
Just got my Krikit I I
Reason: ???
