a little help with a measurement please
i put elkas on mt 14 rt and for some reason i bottomed out the other day on a speed bump, anyone with a 14 rt can you please let me know the measurement you get from the floor to the tip of the frunk. i get 16 inches right now and i took the measurement to the V tip of the frunk because that was the easiest place to get it w/o having to come get the key and move the bike. thanks
i was thinking i ight have to adjust the shocks, will see what others have, thanks
you know men have are hard time measuring
Yep, when they can't see it any more , all they can do is guesstimate on the high side.
That's why we're better at reading maps...
We fully understand the concept of, "Three inches equals twenty miles."
i forgot to mention, i would also like the know the measurement even with stock shocks thanks again
Mine is 18 1/8 to the point on the hood from the ground. Elka's installed that was removed from my 13.
John,
Try four turns on the preload (Twist the spring so that it's shorter), and then take another measurement...
i was watching a vid on you tube and they talk about adjusting them but also mention adjusting the damper also. i just tried to call elka and no answer, so i am going to wait till i talk to them b4 i do any adjustments
Just for a reference, full "droop" is 19 1/4 from the point to the ground so you don't want to be too tight on the springs. Do you know what numbers are on your springs? Mine are stamped 5.8 x 254
waiting on a call back, i had to get the serial number for them i might have the wrong shock, just my luck if it is wrong
