Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 162
Thread: 1330 OIL REPORT
    Mar 2013
    Default 1330 OIL REPORT
    Thinking 9300 miles between oil change is a bit to long I changed it at 6000 miles (9000 on the Spyder) and sent a sample to Blackstone Labs to be tested. Received the report yesterday. Everything came back positive and with a recommendation to wait until 8000 for the next change.
    Looks like BRP got this one correct
    I changed over to Mobil 1 10-40 and will wait the 9300 miles and have it tested again
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2012
    North Las Vegas, NV
    Would be nice to see if the BRP oil would go the distance. This is very interesting and thanks for posting your results.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Apr 2014
    Northwood NH
    Like you, I thought 9000 was a bit optimistic so I've been changing mine at 4000 intervals. I've just been using BRP oil.
    Mar 2013
    Mobil 1 10-40, to clarify, this was the motorcycle specific oil or you used one of their automobile oils with an energy conserving rating.
    It sounds as if you ran the oem oil until 3000 miles for break in, then at 3000 miles went to Mobil 1, hopefully moto oil, and the sample was done on the Mobil 1
    PK
    To clarify - I ran BRP oil and had that tested at 6000 miles (9000 on the Spyder). The first service was done by the dealer then at 9000 miles I changed the oil switching over to Mobil 1 motorcycle oil as I have been using Mobil synthatic oil in all my motorcycles for many years with great results.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by PW2013STL View Post
    That a great report. Could you copy and paste the report here for us to see the numbers? I'd especially like the numbers after cST100c.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2013
    I have been trying, but so far no luck. The number for that is 8.36 and the range is listed at 6.0-9.7
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Hi Les,
    Is this the Mobil 1 you use? Mobil 1 10W-40 Full Synthetic Motorcycle Oil, 1 qt. It says "Racing 4T" on the front in the red portion of the bottle.
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Jun 2013
    Woodbury, MN
    Was the BRP oil the full synthetic or was it the blend when the dealer done the first service at 3000 miles? I believe my dealer used the blend when doing my first service! I've got one more oil change with BRP Oil (blend) before switching due to purchasing it ahead of time.....based on your report, looks like Mobil 1 10W-40 motorcycle full synthetic is the way to go!
    Mar 2013
    Quote Originally Posted by JLSpyder2012 View Post
    Hi Les,
    Jim,
    That is the one. AutoZone $8.99 per qt.
    Thanks for this report!
    Question: Would you suggest using BRP's full synthetic, as opposed to their blend?
    (I'm getting REAL close to the 3,000 mile tap-dance... I'd like to be sure of what to ask for! )
    Mar 2013
    Was the BRP oil the full synthetic or was it the blend when the dealer done the first service at 3000 miles? I believe my dealer used the blend when doing my first service! I've got one more oil change with BRP Oil (blend) before switching due to purchasing it ahead of time.....based on your report, looks like Mobil 1 10w-40 motorcycle full synthetic is the way to go!
    It was the blend for me also.
    Mar 2013
    I considered using BRP's full synthetic, but I know Mobil 1 and it was less $. Their blend (BRP) is doing well so you can use it without worries, but I like the extra protection of full synthetic
    Thanks!
    The 9,000 plus miles between changes, has had me a bit concerned about using a non-synthetic oil...
    Mar 2013
    Thanks!
    If it makes you feel any better Blackstone's report thinks it is good for 8,000 miles.
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default What I have been told
    I will be due for my 12k soon. When I scheduled appt with (this is a new dealer for me) dealership I asked about going BRP full synthetic and he said the same thing that Pitbull said. 'BRP is recommending the BRP blend for the 1330'. Now I know the profit dance about using BRP products . I used full synthetic (AMSOIL) in the 998. Because of the amount that I travel and need to have service sometimes on the road + having to carry AMSOIL I decided to stick with BRP oil for the 1330. Deciding to trust my dealers' knowledge and BRP's recommendation I am staying with BRP Blend as well as following their maintenance schedule...just my decision...I am sooooooo not "smart" in oil...other than olive oil for my culinary excursions!!!
    You guys are making me feel a lot better about my ignorance!
    Thanks!
    Olive oil?
    From the extra-ugly olives??
    Mar 2013
    Quote Originally Posted by murphybrown View Post
    From the report you should be fine as it looks like a quality oil
    Active Member CentralCoastCA's Avatar
    Aug 2012
    Santa Barbara County, CA
    I used Amsoil in my GS with great results before selling it and still have case left over. Glad to hear it's still good for the '14
    Invalid Emails
    Jun 2014
    round rock texas
    Default Break-in period
    Thanks!
    Ive had mechanics say that break-in on a NEW engine should be done with regular motor oil, it helps seat the rings and valves better. Then do the switch over to synthetic oil..I have used Mobil I in all my vehicles and would recommend it..So does Tony Stewart..LOL
    Mar 2013
    Quote Originally Posted by opiewhan View Post
    and that is why I waited until I had 9000 miles on it before changing to full synthetc.
    May 2014
    Texas
    SYNTHETIC OIL MYTHS
    Myth: Once you switch to synthetic oil you can never switch back. This is one of the most persistent myths about synthetic oil—and completely untrue. You can switch back and forth at any time. In fact, synthetic blends are simply a mixture of synthetic and conventional oils. It is advisable that you use the same oil for top-ups if needed, thereby giving you the best protection from the oil that you have chosen.
    Myth: You shouldn’t use synthetic oil in an older vehicle. The myth is rooted in the idea that synthetic oil is “slipperier,” lower in viscosity, or not as compatible with seals and will therefore leak or leak more in places conventional oil might not. Again, completely untrue. Synthetic oils will enhance the engine protection in older vehicles just as they do for new engines.
    Myth: You should break in your engine with conventional oil before you start using synthetic oil. Again, there’s no manufacturer we’re aware of that makes this recommendation. Mercedes, Porsche, Corvette, some Cadillacs, Volkswagen, Hyundai and many other manufacturers’ cars come from the factory with synthetic oil.
    Myth: Using a synthetic oil voids a car’s warranty. Untrue. The only engines that specifically exclude the use of a synthetic motor oil are some Mazda rotary engines.
    Myth: Synthetics made from Group III base oils are not true synthetics and are not as good as PAO-based synthetics in Group IV. Again, untrue. Synthetics made from Group III oil can, in some cases, outperform those made in Group IV oils in some areas of performance.
    Now... You're from Texas; right?
    If they catch you trying to push the use of synthetics, can't they just shoot you?
    Invalid Emails
    Apr 2014
    Northwood NH
    Yup, that's what I hear
    Nov 2012
    North Las Vegas, NV
    So we can conclude that BRP blend is just fine.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    Early SpyderLover posts suggested Mobil 1 (motorcycle) cause permanent clutch damage on the Spyder. I don't know if that is still the case, but wanted to throw this out there.
