Results 1 to 25 of 34
    Aug 2013
    SF Bay Area
    Default Baha Ron's Sway bar installation
    It took lifting the Spyder 22 or more inches off the ground to get the old bar out and the new bar in. Not as easy as the install in an RT. Plus the fight to get the inserts in place didn't help. Worth it though.
    Made a BIG difference in handling. No more fighting it around corners.
    ImageUploadedByTapatalk1405627161.174740.jpg ImageUploadedByTapatalk1405627176.434702.jpg
    Susie - 2013 Spyder ST Limited
    1983-2004 Goldwings. (5)
    Sent from my iPhone using Tapatalk - now Free
    2021 F3 Ltd , Magna Red
    Apr 2013
    United States
    Default Brave man
    Looks dangerous.......but you got it done
    Apr 2012
    Northglenn Colorado
    Yes the ST is a bear to get the swaybar on. I should have taken a picture of how we did it on my friends ST. He wouldn’t let me because it was a complete redneck plan. It involved a floor jack and cylinder blocks. Crank Crank insert cylinder block, Switch sides. Crank Crank insert cylinder block, Switch sides, crank crank and so on. lol
    Titter todder, Hold her level !!!!!!!!, Crank Crank, insert cylinder block.
    Would not recommend redneck process but it was exciting.
    Jun 2014
    Schenevus NY
    What, you didn't balance it on a couple of basketballs and a propane tank?
    Coward.
    Trb--
    Default Done..!!
    yeah some are tougher that others. But you met the challenge and are enjoying the fruits of your labor..congrats..!!
    Must have taken a lot longer than your onlookers thought it would. Looks like they were there for quite some time!
    Aug 2013
    SF Bay Area
    Rich used both lifts. One to get it up and the other just in case something slipped. I held the bike steady while he jiggled it. Made me nervous with it being so high. I helped some but he did most of the work.
    Susie
    Jun 2014
    Granby, QC (Canada)
    I used car ramps to raise and install the swaybar when I did mine on a RT-S 2011 ... this has given me enough clearance to do the job easily. Total installation time was ~45 minutes.
    Quote Originally Posted by dvandal View Post
    Apples and oranges.... Really BIG Apples and Oranges....
    Aug 2013
    Northern California
    Default Read Carefully
    Quote Originally Posted by Topshotta View Post
    Brave Woman!
    Active Member golfsferr's Avatar
    Jul 2013
    Troy, Michigan
    Does it have to be raised that high to remove and install a different sway bar? Is there an easier way?
    Invalid Emails
    Jun 2013
    Port Angeles Wa
    Default only on the st
    Quote Originally Posted by golfsferr View Post
    the st needs to be raised high enough for the sway bar to go vertical in order to remove and install about 22 inches this is not necessary on the RT as the sway bar drops down in the horizontal position after you loosen and wedge the frunk about the thickness of the bar
    You need 18-20" of elevation on all 2013/14 Spyder models to remove and replace the sway bar. There really isn't any way around this other than the guy that had a stairwell doing down in his garage where he just parked his Spyder over the hole.
    This amount of lift is not necessary on any pre-2013 model Spyder.
    Invalid Emails
    Jun 2013
    Port Angeles Wa
    good to know Ron thanks for the info I have your Bar on my STL and my Wife's 2011 RT man what a difference!
    Jul 2013
    Troy, Michigan
    You need 18-20" of elevation on all 2013/14 Spyder models to remove and replace the sway bar. There really isn't any way around this other than the guy that had a stairwell in his garage where he just parked his Spyder over the hole.
    thanks for all the information. I really do want to put one of your bars on my STS. There's actually several things I want to do but until I find the new airflow side panels for my magnesium color STS and get them installed, I'm pausing. Plus now I need to find a good safe cheap lift system to get the 20".
    Active Member pwpalmbay's Avatar
    Mar 2014
    Florida
    Is it worth the money to install a sway bar on an ST?
    Jul 2013
    Troy, Michigan
    Ordered my new panels! So now can anyone recommend a good inexpensive lift system?
    Quote Originally Posted by pwpalmbay View Post
    I sell them so you have to take that into account. But my feeling is the ST needs a sway bar more than any other Spyder model made. That is because the weight/leverage to sway bar spring rate for the ST appears to be the lowest of all.
    The 'S' in ST is supposed to stand for 'Sport'. But the ST I rode leaned a great deal and the Nanny was a constant nuisance in the twisties. But then I tried to ride it like my 2008 GS with Sway Bar installed.
    Hopefully, some ST owners will jump in and give us their thoughts.
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default My 2 cents
    I will chime in. I bought Ron's bar and links. Installed this past weekend and boy oh boy does it ride like a different Spyder! It was indeed a bear to do but worth every problem to do it. I lifted mine just enough to get all the blots out and the upper one's back on the billet links. Then I jacked it up just high enough to get the bar out and get the Ron bar in. Then lower back down and finished it. To me it was more of a pain to remove all the plastic and radiator cover etc. to get to the bar and links. Again kudos to you Ron for doing what the factory should have and should do to these Spyders! It took care of the wind buffering and side wind from the big rigs. Highly recommended for anyone with a Spyder that hasn't already done it. It is money well spent!
    14 RT-S , Stock Large brake pedal White Pearl
    Mar 2014
    Florida
    send me the link, Ron, or direct me to where I can buy this when I'm ready. Sounds like the way to go.
    Jul 2013
    Troy, Michigan
    Does it come with detailed step by step instruction?
    Just email me at fyredad@hotmail.com and we'll take care of you.
    Once the sway bar is in and you experience the potential of what your Spyder can do, there are other relatively cost friendly steps you can take to up your game even more. Believe me, incredible handling can be addictive!
    Yes...
    Apr 2013
    Oklahoma City
    Worth every penny! I had the local dealer install it and the replacement Heim Joints for me.
    Jul 2013
    Troy, Michigan
    Yes...
    please send me a link to get everything I'll need for my STS-SE5 and let me check it out!
    Everything you need (except the jack and tools) comes in the sway bar kit. Email me at fyredad@hotmail.com and I'll sent you a PDF copy of the install instructions for the 2013/14 ST.
