RT SE6 shift error, won't go into first, and Eco mode
2014 RT se6 with 800 miles,
had this happen twice, from a stand still in neutral I tried to shift into 1st with the paddle shifter only to get no reaction. I found if I shifted into reverse and then to first it worked? I have also observed the "E" in the display on two occasions. Not to worried at this time but will have dealer enter in on the work order at first service. The Eco mode was very helpful in learning the best rpm to shift. Seems to be between 2500 and 3000 RPM. I now shift by ear and love the semi- auto and don't need Eco mode on.
i believe the E is gear position sensor error
Originally Posted by murphybrown
Once in awhile I will get the E code (briefly) and sometimes RT will die. ....it can happen either R or 1st gear ... for me it appears to be all about letting "Studly" warm up a little longer...so now I start .. then put on helmet, gloves, glasses and never have an issue. Hope the cure is as simple for your RT.
Thanks, for the most part I do just what you do. Never had it die on me yet.
You did have your foot on the brake didn't you? Took me a bit to figure that out as the earlier ones didn't require it.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
