Results 1 to 13 of 13
    New Zealand
    Default instrument cover 2011 RS Sm5
    previous owner cracked the instrument cluster (speedo, tach, fuel gauge etc) lens. Is it possible to replace just the lens that covers the electronics ? if so could you point me in the right direction to solve this before the dreaded h2o finds its way into the electronics.
    Jun 2012
    New Braunfels, TX
    Default Yes..!!
    Cheapcycleparts.com has the lens for $16.99. Don't know about the dealers but probably a lot more.
    Jul 2011
    Mitchell, Ontario, Canada
    It looks like they got you covered with a part number and how to look up parts in the future. I don't think cheapcycleparts.com can ship BRP parts outside the US. They certainly will not ship to Canada.
    New Zealand
    might be another problem also we use kilometers instead of miles. Ive approach a dealer here see what they say.
    I did go to brp site but for the life of me couldn't find the right fiche.
    just one last q is the total distance covered recorded in that module or is stored in the main computer and retrieved by that module when powered up ?
    Thanks to all that replied
    Shelbyville, KY
    Quote Originally Posted by kiwirs View Post
    I believe that the mileage total is kept in the cluster. If you change the cluster the mileage starts @ 0
    KYSPYDER
    Jul 2011
    When I had my 09 which has the same gage cluster as you, when I crossed into the US I changed mine to miles. When I crossed back into Canada I change it back to kilometers. It take 30 seconds. The instructions are in the manual I believe.
    Here is the picture of the fiche.
    Item 14 is the lens and it comes with a new gasket.
    If you have change out the gage cluster the total mileage is lost and you start over. Why is that a concern? According to your first post the gage cluster is OK, it was just the lens.
    New Zealand
    yes it easy to change the digital display but the analogue is dial is in kilometres in my case, in USA version its indicated in mph
    Yes gauge cluster is ok. I miss-interrupted the drawings.
    Jul 2011
    All the gage clusters are the same. There is no special one for the US. When you change from kilometers to mile the analog gage changes how it reads as well. Hence the constant whining from the US folks on why does their speedometer go to 200 mph.
    Default So..!!
    If you have a problem let me know and I can order one and mail it to you...
    New Zealand
    thanks Ill let you know
    New Zealand
    explains a lot.
    Jan 2015
    Outside L.A.
    Bumping old thread, i have a similar issue. Not that the lens is cracked but seems to have some kind of maybe condensation stain on the inside. If i order a new one how hard or how many pieces of body work and other crap will i have to take off to put this in?
    Thanks!
