Wiring help on 2013 RSS
I am installing an Eastern Beaver 3CS fuse box on a 2013 RSS. I plan to install it on the additional battery terminals that are located under the service cover on the left hand side. There is lots of room here for the box and the relay. My question is that I am looking for a switched hot wire close by to tap into for the switching wire on the fuse box. I would prefer not to use the headlight. I was thinking of the wires going to the left fender. Any thoughts of what is close by?
According to the wiring diagram the 12V outlet is switched.
I used the switched wire for the 12v outlet in the trunk to power my relay.
Sent from my Venue 8 3830 using Tapatalk
