Results 1 to 25 of 26
    Grayslake IL
    Default Gas Capacity - 6.1 Gal + 1 Gal Reserve?
    The title says it all. How much gas, TOTAL, does a Spyder hold? Specs say "6.1 Gallon, with a 1 Gallon reserve".
    How much do you put in with the tank empty?
    i usually fill up with the "get out and push" light on, and I have one bar of fuel left. I put in about 5 gallons and change.
    Am I on "reserve' when all the bars are gone and I am not being smart trying to stretch things to the next gas station?
    "How much gas could a Can Am chug if a Can Am could chug gas?" Or something like that...
    With my 2010 RT; I'd be looking for fuel at about the 135 mile mark... and I'd put in maybe 4.2 gallons.
    Truth is; I never got full comfortable with the fuel gauge on that bike...
    With the 2014; I'm looking to 200 miles as the stopping point... and putting in about 5.2 gallons!
    That leave at least another gallon in the tank... perhaps another forty miles???
    The analog fuel gauge just seems much more accurate, than the one on the 2010!
    Aug 2013
    My 2013 STS says 6.6 gallons.
    Where did you get your numbers?
    Default Here's what you do..!!
    Fill your tank to the filler level....set trip A to zero and drive till your warning light comes on and set trip B to zero continue till you sputter and die. Check mileage on trip B thats how far you get to reserve. Check mileage on trip A and thats how far you get on a tank of gas. pull out your gas can and add a gallon of gas. Set trip to zero and ride till you sputter and die. Thats how far you get on a gallon of gas. again of course now you are out of gas but you know all the specs on gas and your spyder...you may need a frirnd on this one... Sadly everyones outcome will probably be different...
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    You cannot access the last half gallon unless you shake your Spyder upside down.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    The most I have ever put in my 2010 was 5.8 gallons at 184 miles. The analog gauge was below empty.
    I have switched over to the digital gauges, my refuel lights come on at about 150 miles. The digital gauges seem to give uniform readings over time. I usually fill up between 135 and 150 depending on where I am and where I am heading. I always fill my tank to the same level, reset the trip odometer to zero and use that for an indicator as to when its getting time to refuel.
    I have yet to beta test the fuel system on the 2014.
    May 2013
    Redlands, Ca
    You can make your numbers better if you only ride down hill. Really.
    Eastern North Carolina
    There is only 6 gallons of usable fuel due to headspace in the tank.
    Aug 2013
    Quote Originally Posted by bruiser View Post
    Well now how are you supposed to get your head in the tank Silly?
    It ain't easy. Especially when your head is as big as mine.
    Aug 2013
    May 2013
    Redlands, Ca
    Mine has a tank of 4 gallons, with a 2.6 gallon reserve. The trip meter tells me when I'm getting close to the reserve. Today it said 119 when I went to the gas station.
    Feb 2013
    Louisiana
    Quote Originally Posted by claychaser View Post
    Yesterday after fill-up, I rode 82 miles and today I rode another 93 miles for a total of 175 miles on the same tank... The last 15 miles there were no bars... It took 5.4gal to refill the tank. I did this mainly to find my comfort zone ( miles between fill-ups ) for our trip to Virginia in a couple weeks...
    The new analogs seem MUCH more accurate, and repeatable.
    Active Member scarecrow's Avatar
    largo, florida
    I read this this morning and I'm Still ROFLMAO.
    Because I know people that will do just that. lol
    2014 RTS , Cognac
    Grayslake IL
    THANKS! Really love the response! And, yep. it is listed as holding 6.6 gallons.
    It is good to read so many responses and get a general idea of what is going on.
    As for this formula - you have no idea how close I am to doing this.
    If you are going to Spyderfest have a great time. As for me, maybe next year.
    Now THAT's just showing off!
    How have you been? We've mised you!
    Sep 2012
    Virginia Beach, VA
    Default Give Us A Shout When You Get Here!!!!
    Quote Originally Posted by Spyder in La. View Post
    We have a few Spyder-Ryders in the area. Make sure you let us know when you get in our area. Maybe we can set up a meet and eat...or something like that. 'Til then...Ride Safe and Have Fun!!!!
    Feb 2013
    Louisiana
    Quote Originally Posted by ValCruzSpyder View Post
    Thanks!
    Mar 2014
    Broome, Australia
    Quote Originally Posted by SNOOPY View Post
    .... and my 2008 RS says 7.13 US Gal, with no mention of "reserve"?
    John K
    2016 F3-S , Yellow
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by jrk36 View Post
    John K
    I think you need to read your 2008 GS manual again. 25L = 6.6 US gallons.
    Mar 2014
    Broome, Australia
    I'm quoting the 2008 RS Sadness Brochure, I've not converted anything!
    Sent from my Nexus 7 using Tapatalk
    2016 F3-S , Yellow
    Jul 2011
    All models and years have the same gas tank except for the 2014 RT.
    I assume your spyder came with the CE manual and the fuel capacity is on page 120.
    Mar 2014
    Broome, Australia
    Sadness = "official" :-(
    I don't know why there is even a discussion about this - I'm purely reporting what the official brochure indicates - I'm not making that up!
    2016 F3-S , Yellow
    The marketing folks; often have a funny way of looking at things...
    I think that the're better liars, than the T.V. meteorologists!
