Results 26 to 50 of 56
  1. #26
    May 2013
    Stanton, ca
    So if you were to adjust your belt without a reference to the original adjustment, what tools do you need to measure tension?
    From reading this, the tool Lemont used is assuming the belt tension was correct to begin with?
    I am taking mine in for the 600 mile service and my belt is "slightly" up against the flange so I know it needs to be adjusted and I plan to point that out to the dealer.
    Thanks,
    Bob
  2. #27
    Apr 2013
    Mt. Rainier
    Quote Originally Posted by finless View Post
    Thanks,
    Bob
    You can measure your belt tension with the Klicket tool, 236 lbs for the 2013, 101 lbs for 2012 on down. What I did was buy the correct Klicket tool (in my case 100 to 300 lb range) to check belt tension when I picked up my new 2013 at the dealership....By the way, the belt checked out at 200 lbs with rear wheel on ground which is on the low side but I have no vibration issues so I left it that way.
  3. #28
    May 2012
    pell city alabama
    Default I LISTENED LAMONT !
    I replaced my rear tire an brakes adj. belt like you said (rotated tire by hand) everything turned out great no problems with codes or limp mode. Thanks for the info. (I will listen from now on) PETE
  4. #29
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I picked up the Kirkit and fir the life of me cant figure out how to use it. I have read the instructions that can with it. But my question, on the Kirkit in the center where the "blue" part is are you suppose to pull up on it to set it before you apply pressure to the belt? And does the Kirkit reset automatically or do I need to do something manually to it to take another reading?
    Sent from my SCH-I545 using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
  5. #30
    washington state
    I love this post, and thank you so much. Happy , happy , happy to all.
  6. #31
    Feb 2013
    wilmington delaware
    Quote Originally Posted by Littlebadwolf View Post
    I'm looking to buy one of these hitches used if anybody's got one they want to part with.
    good luck ive been looking for 2 years
  7. #32
    Jun 2010
    Austin, TX
    Default RT Hitch removal and belt adjustment
    Quote Originally Posted by M109Dreamer View Post
    The "blue" part is how the Kirkit measures the belt resistance.
    Step 1. Make sure the "blue" is flush with the Kirkit or "pushed down"
    Step 2. Find the center of the belt between the front sprocket and the rear sprocket.
    Step 3. Place the Kirkit centered on the belt and push smoothly down until you hear a "click"
    Step 4. Take the reading
    Step 5. For an accurate reading - repeat the above after rotating the belt
    Hope this helps!
    -Mike
  8. #33
    Mar 2011
    Jackson, MS
    Thanks Mike,
    So just to be sure. I dont have to do anything prior to the Kirkit? Just push down evenly till I get the "click"?
  9. #34
    Jun 2010
    Austin, TX
    The Kirkit works just like a torque wrench.....except you do not set it first. The "click" your hear will be the belts tension - kinda automatic.
    -Mike
    <Sent using Tapatalk>
  10. #35
    Mar 2011
    Jackson, MS
    Quote Originally Posted by SpyderFun View Post
    -Mike
    Im tracking now, thanks!
  11. #36
    Jun 2010
    Austin, TX
    Glad to help!
    -Mike
  12. #37
    Active Member TroyboyRn's Avatar
    Appleton Wisconsin
    HEllo
    I have a 2010 RT-S. Ive read all the threads and am a bit confused. What is the belt tension range for my Spyder. Thanks
  13. #38
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    Quote Originally Posted by TroyboyRn View Post
    HEllo
    My 2010 RT S runs about 180 lbs. with the krikit. that is where it has been since new. Anything over 200 seems too tight to me and could cause bearing problems.
    Happy Spyderlovers
  14. #39
    May 2013
    Stanton, ca
    HEllo
    Can I just add.... The belt tension spec is SOOOOOO liberal that it's not rocket science. Scotty can jump in here but the current spec has a 30% variability range! It surprises me that with this HUGE range you even need a sonic gauge! It's like WTF?????
    This is my honest opinion now that I have adjusted my belt AND watched many videos and other peoples posts on the "value" they read using the Kirkit gauge! Even from Lamont using the Kirkit gauge!
    IT"S NOT FREAKIN THAT CRITICAL!
    I did what everyone said. I went and got my 600 mile service and they DID adjust my belt. I know that because my tracking on the rear pulley was off and after service it was spot on! Then, that same day, I got a Kirkit and read the belt tension. It turned out to be EXACTLY like Lamont's video and others that used the Kirkit doing the same as I.
    What did this tell me to be honest... IT'S NOT ROCKET SCIENCE! It's not a VOOODOOO adjustment! And I am sorry... You don't need a expensive sonic gauge either! Why BRP does this is beyond me. Maybe they are trying to take into account that not all replacement belts are the same or something?
    NOTE: If I had to replace my belt ONLY THEN would I consider the sonic adjustment! Even then I might just freakin say... screw it... I will do it myself.
    Your mileage may vary but for me, I wont go to a dealer and spend $100 for a simple belt adjustment. I would be willing to bet right now that a few years from now, I will report back here that I have had NO issues doing this adjustment myself.
    My .00000002 cents!
    Bob
  15. #40
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Curious was checking mine and just tightened it 90' on each side keeps creeping to the outside so I tried tightening left keeps creeping left. How do you get it aligned from scratch if neither side is like it left dealer? Book says same as Lamont if want it right tighten left vice versa can't get it to quit creeping left.
    Sent from my HTCONE using Tapatalk
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
  16. #41
    Apr 2012
    SW Austin
    Ran it after fiddling with it several hours between Sunday night chores got it close test drove it was a tad on the inside so I jacked it back up adjusted it little more. Not rocket science like its been said but helps to get it close enough for govt work!
  17. #42
    Jun 2010
    Austin, TX
    Hello I have a 2010 RT-S. Ive read all the threads and am a bit confused. What is the belt tension range for my Spyder. Thanks
    Keep in mind:
    1st) its just a drive belt for a motorcycle...nothing more than that.
    2nd) the "sonic" adjustment can be converted to an applied "pounds" of force.
    3rd) BRP has "over complicated" this procedure by "Rube Goldberg"(ing) it.
  18. #43
    Maine
    Default belt tension
    Why is the belt tension so different between the 2012 and 2013?
  19. #44
    Feb 2012
    Spring City,Utah
    I see that no one has replied to this question. As I hope to be buying a left over 2013 soon I too would like to know the answer to this question.
  20. #45
    Dec 2014
    ventura, ca.
    so... let me try to get this straight.. lamont says 150 to 200 lbs. using a krikit.. that sounds right.. then service bulletin #2010-6 says 450 plus or minus 150 newtons, which means 67.4 lbs to 134.9 lbs... that just sounds awfully low... but the threat of doing harm, with too much tension, has me worried..... lamont, are you aware of that service bulletin 2010-6 ? .. those math conversions have my little brain spinning....
  21. #46
    Jun 2010
    Austin, TX
    Default Belt Tension Math - Simplified
    Quote Originally Posted by chuckk View Post
    If BRP uses the "newton" as a way of measuring force, then simply multiply the *NEWTONS REQUIRED by 0.224808943 which is ratio of 1-newton to 1-pound.
    Also, 0.2 is 2/10 which is reduced to 1/5 (i.e. 0.25 is 1/4). A "ball park" estimate, if you have no calculator, is to take the newtons required and divide by 5 (you will be "light" but you will have an idea of what it should be). So a "ball park" rough estimate of 300 - 600 Newton requirement is about 60 - 120 pounds. AND you will not be applying "excessive tension" to the belt. This is how other owners come up with their tension numbers.
    Google: http://www.convertunits.com/from/Newtons/to/pounds
    * = BRP can change this requirement at any time but the math remains constant.
    Hope This Helps Clear Things Up!
  22. #47
    Nov 2014
    FL
    nice tutorial u got there buddy
  23. #48
    Sep 2015
    Metairie, LA suburb New Orleans
    I'm getting a aggravating vibration when going up hill in 6th gear (bordering on lugging the engine at 3800 rpm) which I believe is the belt.
    Is a vibrating belt caused by too high a tension, or too low. Recently, my dealership replaced the back tire with stock, so the belt was off, inspected, aligned, and put back. I notice the belt is against the pully ridge (back?) with very little space showing. They also claim they are up to date on tension and used the correct spec.
    any comment ???
  24. #49
    Default BELT TENSION
    ......I have always had the tension on My 14 RT well below spec ( even the lowered one ) and have NO vibration.............I don't have any add-on tension devices either ........Mike
  25. #50
    Bossier LoUiSiAna
    With all this said i see a need for a vendor service @ spyderfest. Much like the alignments, yall agree?
