Results 1 to 25 of 33
    Inactive User
    Mar 2012
    Spokane, WA
    Default UURG new rear tire
    8500 miles and I need a new rear tire. Bald down the center. Frustrating because tire pressure and oil level are the two things I try to stay on top of. I have been running 2lbs over because I like the ride. must have overfilled at some time and didn't notice. Just a word to all check tire pressure can be expensive not to.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    It can also be due to ballooning of the thin-carcass tire at freeway speeds.
    Inactive User
    Mar 2012
    Spokane, WA
    75 or 80 mph for extended time? I usually travel 65 to 75 on the hiways around here. Could this be the cause? If so what do I do? Car tire for rear?
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Probably the most popular replacement for the rear would be Kumho 225/50R 15
    2008 GS.....PE # 2888
    Jun 2010
    Las Vegas
    Maybe you should try the new Arachnid tire being offered by spydercomfort.com
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Inactive User
    May 2011
    Charleston,SC
    My back tire is like that also but I have over 25k miles on them,so I'm not complaining. I use Ride on in my tires and I believe that's the difference.
    Inactive User
    Mar 2012
    Spokane, WA
    I have not heard of "RIDE" what is it?
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Default Ha a new Kumho 22550R15 installed today
    I had almost 8600 miles on the oem and was told I had maybe another 1000 miles left, but with a 750 mile round trip to Spyderfest coming up diecided to go ahead and replace it. I was already at the shop and had the tire with me, so went ahead. I didn't notice an difference in handling on the 30+ mile return trip. Louis Power Sports in Greenville, TX put it on for me, I can't say enough good things about these guys, it's where I bought my RTS and they hey have done all my service work.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Inactive User
    Aug 2013
    Quebec City, Quebec
    Falken tire is also a very good choice for rear tire.
    Inactive User
    May 2011
    Charleston,SC
    It's Ride-On sorry I forgot the dash,you can go to http://www.ride-onshop.com to see there products,I will being buying more of my new tirs soon.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Showie View Post
    Speeds over 50-60 mph will increase rear tire center wear due to ballooning. Different tire pressures may aggravate this problem...especially low tire pressures from what I have seen. Lots of straight roads also seem to wear the center more.....or at least wear the sides less.
    I note you have a 2013 RT. Hopefully that is not going to be the pattern for rear tires on 2013 and 2014's. I am used to getting between 13K and 15K on the rear tires. I sure don't want to get into the mode where I have to replace rear tires twice a year.
    Inactive User
    Ozark, AL
    I also have noticed that the rear tire wears extremely fast on my 2013 RT. I ordered a new Kumho at 7500 but haven't put it on yet. I plan on using balance beads (worked well on my Royal Star Venture). What tire pressure is recommended for the pc tire...same as OEM or different?
    Inactive User
    Mar 2012
    Spokane, WA
    Quote Originally Posted by Hueydriver View Post
    Good question. I was just going to use manufactures recommendation but on a it may be different.
    Inactive User
    Jun 2011
    Lynden, WA
    I mentioned this before, I got 17K on my stock tire then changed to the Kumo, it wore like iron but hydroplaned way too easy. I live in the great northwest so wet road performance is paramount.
    I'm going to watch close and see how the beta testers do with theirs. It should be mid summer before I hit 8,000 miles.
    Inactive User
    St. Catharines, Ontario
    Default Rear tire change
    Just changed my rear tire to a Kuhmo from the OEM Kenda. Got the 38500 kilometres out of it. I am using ride-on with the new tire.
    Inactive User
    washington state
    Hard riding and spinning tires (burning) will eat up any tire.
    Quote Originally Posted by tigerdr View Post
    I ran a Falken for 8,000 miles.
    It was a very comfortable tire...UNTIL it got worn down close to the wear bars... then it became a hydroplaning disaster!
    Use it; but replace it quickly when it starts "talking to you", in the wet!
    Invalid Emails
    Sep 2009
    west Texas
    Depending on conditions, 8500 miles on the stock Kenda tire is not too bad. I got 9500 miles on my original rear tire and 7500 on the second one although it wasn't completely worn out when I changed it. Changed to a Kumho and got over 14,000 on the first one, working on a second. Remember that the original Kenda is technically a motorcycle tire with softer compound and a more flexible sidewall than a car tire. Lots of GoldWing and BMW riders would be happy to get 8500 miles on a rear tire. I know I would have on my BMW.
    Cotton
    Inactive User
    Mar 2011
    lake city michigan
    Default rear tire wear
    I just changed my rear last weekend. Been getting 12,000 to 13,000 on stock tire. All wore in the center. When they get to the wear bars they go fast. I ride 60-65 most of the time. I ride 2011 rt-s.
    Inactive User
    Default Lucky..!!
    I guess. Have 18,000 miles on my Kenda and still have not reached the wear limit. Center groove is gone but still have a bit left to get to the wear bars. Don't do a lot of freeways but when I do it is 80-85 mph and average 60 on the back roads twisties and hills. Mostly double up but do have an RS...
    Inactive User
    illinois
    Default rear tire
    I got 15,000 on my original rear tire , center wore out first , I tried putting 20 lbs. of air instead of 28 lbs. of air , it still wore in the center. Going to change the tire next week. Going to put on a KUMHO this time.
    Nov 2012
    North Las Vegas, NV
    We got 8700 on the Kenda, still had some tread but wouldn't make it through inspection. Put on a Michelin Primacy 215-60-15. The wife says she notices no difference from the Kenda , I think it rides a little better. My two wheeler wore out the back tire in 4600 miles.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Quote Originally Posted by bikeguy View Post
    Cotton
    Interesting you say that. I got upwards of 18,000 miles on the rear and 16,000 on the front on my 2005 Goldwing. All were Dunlop Elites. I was expecting the Spyder to do better since there's no tire leaning.
