Anyone used/using Mobil 1 Racing 4t 10w-40?
Anybody ever used it? Any issues with the weight? Used it in my Ninja without any problems.Any other suggestions besides BRP.
I'm about as ignorant about oil, as a hog is about The Sabbath...
...But aren't there specific ratings, that specify whether or not an oil is suitable for use in bikes?
Does Mobil 1 carry those designations?
Mobile 1 racing T
Used it in my Kawasaki Vulcan 900. Recently used Amsoil in my Victory and am planning on using Amsoil in my spyder.
I will have to look when I get home. Sadly, no Spyder or manual with me.
The oil he is listing is a Mobil 1 for bikes
Think there is 5w40 recommended for the summer 10w40 is a thicker grade not. Whole lot but I thicker . I haven't had mine long enough to experiment with oil in my bike. Maybe someone will chime in that has
I used it for about a year in My GS BUT changed to Castrol RS 4T 10w40 Because its JASO Rated MA2 which is better for the clutch!
2015 F3 SM6, Custom Dynamics fender lights.
Sea Doo GTI-SE 90 Jet Ski!!
I won't
Mobil one is Rated SM and BRP warns not to use oil rated SM.
Ah I see! Thanks for that
I've used Castrol for years in cars without problems. I shall see about it for the Spyder.
Some people have used it with no problems. Others reported clutch difficulties. BRP prohibits use of SM oils. I personally would avoid it unless I was 100% sure. There are other alternatives that are not as questionable.
No problem with using 10W-40. Most of us do, even though it is slightly above the recommended winter viscosity. If I lived above the arctic circle I might think differently, but for most of us it works just fine.
You might want to check out Valvoline Synthetic 10-40 motorcycle oil. It meets all requirements and is Jaso Ma2 rated. I lab tested it once in my previous RT, and it tested out almost as well as Amsoil. You can find it in most Walmarts. And its far better than the Castrol Blend cycle oil.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I am not busting your butt on this, but can you explain further where to find or why is SM rated oil prohibited.
This is copied directly from the manual, I have made obvious the BRP statement that says or higher classification. Seems to me, the minimum acceptable is an SG rated oil. SM would well exceed the minimums?
Use the XPS 4-STROKE SYNTH.
BLEND OIL (SUMMER) (P/N 293 600
121) or a 5W40 semi-synthetic (minimum)
or synthetic motorcycle oil
meeting the requirements for API service
SL, SJ, SH, SG or higher classification.
Always check the API service
label on the oil container.
Again, I am curious, not starting anything. My main reason is my plans are to use Mobil 1 motorcycle oil. But may use Rotella if acceptable.
It should really just come down to if the oil has friction modifiers or is labeled "energy efficient".
This is what I am using for info
http://www.mobiloil.com/USA-English/...T_10W-40.aspx#
Rotella also meets SM, just not sure if it has friction modifiers
API CJ-4, CI-4 PLUS, CI-4, CH-4, SM, SL, SH; ACEA E9; Caterpillar
ECF-3, ECF-2; Cummins CES 20081; DDC 93K218; Ford WSS
M2C171-E; JASO DH-2, MA; Mack EO-O Premium Plus; MB Approval
228.31; Volvo VDS-4
PK
Does not apply to you.
228.31; Volvo VDS-4
PK
If you will notice the OP has a GS/RS model spyder with a 991 series engine. In all owners manuals for this engine there is a warning not to use SM rated oils because clutch damage will occur. There are lots of choices for oil so why use one that manufacturer says not to use!! As for Rotella T6 oil I tried that on recommendation of other folks in my 09 GS and the clutch started slipping.
In regards to you and your 2014 RT with a 1330 ACE engine. Your owners manual has no such restriction. So what is correct for the OP may not be correct for you.
Not to jump into an oil thread, but that oil is fine for use in the Spyder. It has the same basic ratings as the Amsoil that is the favored product by many owners, myself included.
I believe what BRP is referring to in the manual about prohibiting SM grade oils is a direct reference to automotive SM oils, which was the automotive industry standard from 2004-2010, and not oils approved for wet clutch applications, like the referenced Mobil 1 product.
BTW, the SM rating was susperceded by the SN rating in 2010 by the API.
Here's a good link explaining things.
http://www.carbibles.com/engineoil_bible.html
http://www.amazon.com/Castrol-06078-...Motorcycle+oil
I buy my Castrol here. 6 Pack for $44 No Tax, Free Shipping!
When I bought the RS 4T at Advanced Auto it was $9 a quart times 6=$54 Plus $3 + Tax= $57
Saves me about $13!!!! I buy everything I can from Amazon.
See post #13 above. BRP clearly states in the owners manual for all but the 2014 RT...
To avoid damaging the
clutch, do not use a motor oil meeting
theAPI serviceSMor ILSACGF-4
classification. Clutch slippage will
occur.
You can't get much clearer than that. Use any oil you want, but don't come crying to BRP for warranty repairs if you use an oil that they specifically prohibit and you subsequently experience clutch failure.
Saving money, can sometimes cost you; BIG time!
My apologies people. After rereading the original post and replies I was asking myself, where or how did I not see it was a non 1330 topic or noted in the ops signature.
I realized my error, I had replied to posts viewed from the "What's New" method and did not realize I was in this category.
So yes, disregard the statement to use SM rated oil made by myself.
PK
MOgang Member
Choose Carefully...
Have a '09 SM5. Mom and Pop are happy when I come in. They're still selling the old oil on sale. Spydee loves it!
http://www.spyderlovers.com/forums/s...+racing+10W-40
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
I've used the Mobile1 4T ever since the bike was new in 08 and haven't had any problems with it.
Results have been mixed, from what I hear. SM or SE? SEs ridden at marginal rpm fare worse. How old is your stock? The old Mobil1 was not rated SM. The problems arose after the change, but there is still some of the old stuff out there.
Mine is a SM. Not that old.
Glad it worked for you. It has not worked as well for some others. Be aware that use of SM oils in the Spyder (except 2014 RT) is prohibited by BRP, so there could be warranty issues for an oil-related failure.
I been using Royal Purple
