Results 1 to 9 of 9
    Feb 2013
    Canada
    Default Can-Am SPYDER Billet Front Axle & Nut kit
    Hello,
    Do you know if the Can-Am SPYDER Billet Front Axle & Nut Kit "is compatible with the Can-Am Spyder RSS 2012? (Manufacturer Part #: 219400116)
    Springfield, MO
    This kit is http://store.spyder.brp.cust.shopatr...oltNut_Cap_Kit
    Not sure where you found the other kit part number but they should all be the same.
    Default Welcome..!!
    welcome to the site...
    Feb 2013
    Canada
    Thank you, but it's not the same thing ! This is the suspesion bolts parts.
    I want this parts ! http://www.amazon.com/Genuine-Spyder.../dp/B0035QN25G
    Thanks !
    Springfield, MO
    Yes, those should work on the 2012, I don't see any reason why not. It looks like BRP quit making them.
    May 2011
    USA
    It is not compatible with any Spyder RS or RS-S from 2011-2012 due to the spacers that BRP added on the fender brackets which push the kit out so far that they contact the front lower shock mount. This could cause a possibly very dangerous steering issue. If you purchased them you would know they are not compatible because the mounting bolts that come with them are not long enough. Still BRP should have made it very clear that mounting the kit on a 2011-2012 RS or RS-S could be dangerous. The 2013 model comes with with newly designed axle covers standard.
    Springfield, MO
    Quote Originally Posted by pro10is View Post
    Didn't consider the spacers. I take it you've tried this already?
    May 2011
    USA
    Quote Originally Posted by Lamonster View Post
    Yes, the only way anyone would have ever known that they wouldn't fit was to buy a set and try to install them on a 2011 or 2012. Nowhere was it listed on BRP's site that they were not compatible. I'm not sure BRP even realized at first that the kit would be affected when they added the spacers. Eventually BRP dropped the kit from their site most likely because of the fitment issue but there's still a lot of these kits out there still being sold.
    I ordered a set for my 2011 RS-S. I was quite upset when they didn't fit and couldn't be returned. I was finally able to make them work but I had to order larger bolts and have a half inch machined off of the bottom of the cover. But I would not recommend this to anyone else. If not done just right the covers will contact the lower shock mounts and in all likelihood jam the steering in a turn.
    Invalid Emails
    Sep 2012
    Clermont Florida
    Default billet axle cover kit
    I just received the kit from a trade and wow they do fit a 2012 RSS using longer Allen screws,Also the clearance in relation to the lower shock mount is correct for steering and suspension movement. The cone shaped cover looks great I'm happy happy.
    Mike
