Results 1 to 12 of 12
    Registered User
    Apr 2008
    Colorado, Bailey
    Default Fender Brace Breakings???
    So far I've had four front fender braces break on my RTs. Wondering if this is due to hard use by customers or are others experiencing this??? The only thing I can think of is stress from hitting bumps, cracks, pot holes and maybe on/off the side of the roads causing the extra stress. But always breaking in the same place... lower part.
    Anyone else have this going on?
    Jun 2012
    Greenfield, MA
    well
    Jun 2013
    Quote Originally Posted by GnA View Post
    I haven't seen anything . . . what year and how many miles?
    Jun 2012
    Cumberland Cove - Monterey, TN
    We have a 2012 RT-Limited with 13,000 miles and lots of them ridden hard in the hills of Tennessee with nary a broken brace.
    Carl
    Default Let's see..!!
    Have not heard other than yours. There may be others but not common. If you are on a lot of rough roads this could be the problem. Still seems strange. Both sides, one side, do you have other steering issues like bearings ball joints etc..??...
    Registered User
    Apr 2008
    Colorado, Bailey
    No, no other steering issues... both sides, front and back braces. Can't figure out why. Broke when mileage in the 30 and 40k areas. 2011 models..... just wanted to see if many other were having this issue.
    Default YES YES AND OH YES
    Been there done that.....I live in Vermont and some of the " Gravel " roads have lots of wash-board (lots of small bumps similar to a washboard)....really plays havoc with front end.......I had to weld supports onto both struts of both fenders......There was no rust inside they just fatigue broke.......Then I come to realize that my front SHOCKS had cr*ped out and really weren't doing their job and MAYBE this is what precipated the failure......I only had about 16,000 miles on them ...This was all posted quite awhile ago .....It 's in the archieves somewhere........PS mine broke right at the BASE near the HUB (?)......good luck.....Mike
    Registered User
    Apr 2008
    Colorado, Bailey
    Thanks, Mike!
    I hate to metnion this ...
    Have you checked to make sure that everything is nice & tight??
    Active Member mooneych's Avatar
    Aug 2010
    South Riding, VA
    Default Broken fender mounts
    A search in the box to the upper right for "broken mounts" returns 17 results.
    The GS/RS bikes have had problems with the rear fender braces; this is the first that I've heard of the fronts breaking that often...
    washington state
    I just show how much you're having fun. But seriously check your bracket mounts for proper installation.
